Re: Werid spot in paint
Originally Posted by Dadillac
Wet the area. Does it go away? If so I would add some clear from a spray can and wet sand it smooth. If it doesn't change when wetted than I would say that the base coat is at fault.
Don
Thanks for the advice Don. I will try it out tomorrow and post back the results.
do not use spray can clear unless it is a 2 part one.
also use wax and grease remover and tack down the surface. you could scuff up the surface with some 3k wetsandpaper for better adhesion...
Oh no worries, I wouldn't bother doing that myself. If I do the wet test and decide it is in fact clear that is missing then Ill just drive it over to the body shop and get them to throw some on for free. Thanks though!
Its a porche. Just have it repainted the right way instead using crapy spray can clear. Your asking for really bad orange peal and runs.
Not to mention failure of the clear in the months to come. If that car is to be sold, I would have it fixed the right way or let the flaw be seen by potential buyers. Masking it in some way so it cannot be seen is a little shady in my eyes.
I have had pretty good results with spray cans. Do it right and it looks as good as factory paint. Light coats and wet sanding afterwards. My brother in law has also painted an entire car with spray cans. Took a lot of work to get it right but it looks as good as a quality respray. And it is holding up very well. The only drawback to spray cans is the finished product will almost always be quite soft. So swirling and scratches are an issue.
Don
Don
there are 2k rattle can clear and primer. these have hardeners......
looks to me like whomever "butchered" it with a rotary heated up the paint to much which caused the metallics in the base to disorientate, which isn't because of burning through but actually heating the paint too much.
i would like to say im wrong here, i believe i was thinking of something else while i wrote that haha, i saw this once before on a new jetta from the factory and i had to repaint the panel at my work under warranty. i didnt know what had caused it because nothing was wrong with the clear and in this instance it was oval shaped.
By Dronyn in forum Auto Detailing 101
Last Post: 03-01-2020, 10:55 PM
By mycarmycar28582 in forum Auto Detailing 101
Last Post: 03-14-2016, 10:39 PM
By Shark Politur in forum Show N' Shine
Last Post: 08-18-2015, 12:04 AM
By slacknh in forum Auto Detailing 101
Last Post: 09-16-2012, 11:37 AM
By timaishu in forum Ask your detailing questions!
Last Post: 09-11-2011, 09:06 PM
