Recommend a polisher and sealant for outside truck
I will be purchasing a DA soon, either a PC or a Griot's. My truck is a 2008 white Tundra and I have to park it outside. I have read and searched numerous threads and info but haven't found an answer.
Which polisher and sealant would you recommend that will hold up to the outside and sun? I live in SoCal. Also, I will be buying some 5.5 inch foam pads. Which ones would you recommend? My paint is in decent condition. Minor swirls and some offroad brush marks from shrubs.
Thanks in advance!!
Re: Recommend a polisher and sealant for outside truck
Thanks in advance!!
Griots 6" DA along with 3 each of their two different pads. I wouldn't worry about buying the 5.5's at this time. You might also get 2 - 6'5" Surbufs. They will fit perfectly on the factory backing plate
Menzerna Power Gloss for your sealant
The GG has more power and maintains pad rotation under pressure better than other DA Polishers, this is helpful when doing any correction steps.
Thin, small diameter pads rotate better under pressure than large, thick pads. The Griot's Garage 6" pads are about 1" thick and the tool can easily rotate them but if you're going to be buffing more than just your truck then look into getting a 5" backing plate and 5.5" pads.
Any of the 5.5" pads work great, it really comes down to personal preference, the CCS, Flat and Hydro all will get the job done.
See this article as it has pictures of the pads and the backing plates plus links to the store for more specific information about each...
The principals discussed in the below thread apply to ANY DA Polisher including all the current versions...
How to maximize the ability of the 1st Generation Porter Cable Dual Action Polishers
This one is good too...
Thin is in... New Lake Country Hydro-Tech Low Profile 5 1/2 x 7/8 Inch Foam Pads
There's a lot of topical articles related to buffing out your truck in my article list...
How-To Articles
Flash, did you mean Power Lock? Power Gloss is a cutting polish not a sealant.
Oooops
Thanks for picking me up there S2K
Coatings are proving to provide longer lasting protection than traditional waxes and sealants, maybe take a look at one of these options.
3-Categories: Waxes, Paint Sealants and Coatings
Wow! Thanks to everyone for the great advice. I have a lot of learning to do. Can't wait to begin!
Thanks!
all sounds good . same recomendations i received when I asked for help . yet I'm topping powerlock with 845 .
By my01ws6 in forum Auto Detailing 101
Last Post: 10-13-2016, 12:07 AM
Last Post: 04-19-2015, 09:46 PM
By bubbyrhoads in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 02-05-2015, 06:39 PM
By dX 412 in forum Auto Detailing Tools and Accessories
Last Post: 04-06-2011, 06:16 PM
By Ack in forum Auto Detailing 101
Last Post: 07-01-2009, 09:45 AM
