M105 Caking Up?
Lately, M105 has just been getting on my nerves. I have been having it cake up more and more on me and am curious as to why its happening. I can only assume its from lack of moisture in the compound. But after yesterday I am fed up with 105. When I was working on this yesterday...
I would apply 105 in a nice 2x2 area, and within 5-10 secs of me turning around and grabbing the buffer it would have already caked up, to where if you ran your finger through it, it was almost dust.
It did the same for 205, just not near as bad. So I tried different chemicals, and 3M 3000 Machine Polish did not seem to have a problem, or Menzerma Super Finish hor even with Ultimate Compound by hand.
Any idea why this would be happening. I figured maybe the severe oxidation in the paint, but its also happened on other vehicles I have done, that are in better condition. Now not near as bad, but enough to where I would put a coat down to buff, and then spritz it with water before buffing to get it to work in correctly.
Re: M105 Caking Up?
What was the temp outside? Have you kept the polish in extreme heat for storage? How old is it?
:dancebanana:
Sky's the Limit Car Care
Re: M105 Caking Up?
Considered these things as well... Temp was about 50-55 degree's, polish is stored in my garage in a shaded area when not used., and its only about a month old.
Re: M105 Caking Up?
just a stupid question----you were in the shade, correct?
Robert DiTerlizzi, 772-260-6636
Impressions Fine Automotive Detailing
7656 SW Jack James Dr.Stuart, Fl.
Re: M105 Caking Up?
I've had this happen nearly everytime I've used M105. I, too, have to spritz it with water just to be able to work it. Very frustrating.
Colin
SELF BANNED
Re: M105 Caking Up?
Looks like you were working outside. If you use too much or outside and and spread it around it will dry out like that. Also when you spread it out the air from the buffer will dry it out. You are going to have to make adjustments to the amount you use, also looking at the picture you are spreading it around too much so it is going to dry up.
Re: M105 Caking Up?
lol very stupid question...yes I was in a garage working. been detailing to long to compound in sun light!
Re: M105 Caking Up?
I can think of a couple things happening. 1 your pad had to much compound on it causing it to cake up. 2 if you are using a rotary or a flex da your letting the product get to hot causing it to cake up.
Those are the only 2 things I can think of if you are working in the shade.
Re: M105 Caking Up?
Was not working outside. Also thought about the amount and to thin drying out fast from the buffer. Then also thought about like you said applying to little, so even tried the same amount in a smaller area and got the same affect.
1. this picture was taken on the first buff after I ran the brush over the pad cleaning it out. 2. this was buffed at 1500 rpms and 1 pass, so not even time or pressure to heat the compound/paint up
Re: M105 Caking Up?
Try a different bottle of 105 you could of got a bad bottle. The only time this has happened to me was what I posted before.
By Superman0440 in forum Auto Detailing 101
Last Post: 10-03-2013, 04:47 PM
By flaco in forum Ask your detailing questions!
Last Post: 08-17-2010, 01:44 PM
By O.C.Detailing in forum Ask your detailing questions!
Last Post: 10-07-2009, 10:44 AM
By slawek65 in forum Auto Detailing 101
Last Post: 04-07-2009, 11:24 AM
By scottgt in forum Auto Detailing 101
Last Post: 02-20-2008, 01:11 AM
