Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Dec 2017
    495
    303 aerospace protectant
    Hi just about to apply to the dashboard of my car.
    For 2 coats, how long do I leave the first before recoating?
    Can I use a Meguairs (yellow) foam applicator to apply?
    Thanks in advance
    Dec 2011
    Pompano Beach, Fl
    1,494
    Re: 303 aerospace protectant
    A foam applicator will work fine, I like a microfiber brick instead, it seems to get more coverage. The real key with 303 is put it on so the dash looks completely wet, wait 10 minutes but then buff it several times to get rid of the oil sheen. I think there are better things out there than 303 after having used it for five years, but 303 is a great product.
    If you make sure that you get all the area covered and don’t miss any spots, there is no need for a second coat. You’re just wasting product.
    Glen -
  3. Likes RTexasF, MisterSnoop, SANTA3013 liked this post
  4. #3
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    I also use the microfiber covered sponge. I spray the sponge, one side only, rather than the dash. Once you get 303 on the inside of the windshield at the base of the dash it can be a real bugger to clean the glass.
    Rick....now in North Texas
  5. Likes Hermes1, Azure liked this post
  6. #4
    Super Member Hermes1's Avatar
    Sep 2014
    Nomad, wherever we park our rig
    255
    I too prefer to use a microfiber sponge for better control of where it goes, but it can be sprayed on the surface as well.
    Sincerely, Bruce
    2015 Ram Big Horn CC 3500 Cummins DRW w/AISIN tranny
  7. #5
    Dec 2017
    495
    Quote Originally Posted by glen e View Post
    Thanks
    Ok so wait 10 minutes not buff straight away.
  8. #6
    Dec 2017
    495
    Quote Originally Posted by RTexasF View Post
    Yep experienced that with the glass. I spray the applicator as well.
  9. #7
    Dec 2017
    495
    Quote Originally Posted by Hermes1 View Post
    Thanks.
    Where else do you use it?
  10. #8
    Jan 2017
    Byron Canter MI
    97
    I second one coat with microfiber sponge...and avoid touching any window. Wipe down is optional but I think that's dependent on the look you want and the type of surface. I think 303 is an awesome product and doesn't look oily. I apply it about 3-4x per year whenever it looks like it's dried out. I apply it to all of the dash and doors including plastic covering the gauges, laminated wood, steering wheel, door panels and trim, and vinyl surfaces.
  11. #9
    Dec 2018
    7,217
    Yeah 303 never truly dries and one coat looks kinda “greasy” second coat would be too much. I don’t actually waitca specific amount of time.
    Just coat entire interior and then go back around from where i started.
    If not a fan of 303’s wet look give PBL Leather&Vinyl coating a try.... worth the $$$
  12. Likes dwaleke liked this post
  13. #10
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    I use a MF towel. I have never tried the applicator and buff with towel method. I usually put it on thin enough that it doesnt need a buff
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  1. 303 aerospace protectant what it can do
    Last Post: 02-12-2021, 12:56 AM
  2. 303 Aerospace Protectant on car paints????
    By mrq0604 in forum Auto Detailing 101
    Last Post: 06-12-2018, 09:51 AM
  3. What do you use 303 Aerospace Protectant for?
    By emmjay in forum Ask your detailing questions!
    Last Post: 12-10-2015, 11:48 AM
  4. Aerospace 303 Protectant
    By descout in forum Products Guides
    Last Post: 10-20-2015, 07:09 PM
  5. optimum leather protectant vs 303 aerospace protectant
    By benzer77 in forum Ask your detailing questions!
    Last Post: 03-17-2011, 06:41 AM
