2013 VW GOLF Sportline - 'Revival' + Pinnacle Black Label Coatings
Dear Friends,
This week I had the pleasure to work on a 2013 VW Golf Sportline. The car was very neglected but during evaluation I could see huge potential for a full refinishing work.
I'll let the pictures do the talk, and I hope you enjoy watching!
START
Car arrived, let's take a look:
Getting closer so you can see the real condition of the vehicle
Embedded contaminants made the car look much older than it actually is
Inside and out,
Mostly everywhere
Let's start looking at some results.
BEFORE
AFTER
BEFORE
AFTER
More on this subject:
Tacky!
The lack of proper rubber cleaning and care was causing that ugly staining on painted metal in contact with it:
After cleaning the rubber seals, I degreased interior of doors using a tar remover, then hand polished every inch of it:
I've worked Menzerna PF2500 with a Microfiber Applicator to achieve acceptable results.
Put some passion under that pad, and move it at speed of light... The literal definition of 'Elbow Grease!'
Sweat, but worth it
Finished results on driver's side:
Passenger's side
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
ENGINE / BAY Detailing
This part wasn't very dirty because customer had already cleaned it recently
However, he used improper cleaning material, causing a lot of scratches under the hood.
To improve this part I've polished under the hood both by machine and by hand. Here are some pictures of the process which consisted of a 2 step polishing (PF2500@orange pad / by hand, SF4000@white pad / by hand).
Finishing by machine
Improving the results by hand polishing
BEFORE
AFTER
A microfiber towel was also used to polish some parts
After polishing, I've wiped everything with Eraser then coated using Pinnacle Black Label Surface Coating
Although customer cleaned engine recently, it still could get some improvement.
BEFORE
DURING - Giving it a shine
AFTER Cleansing Step
AFTER Conditioning Step (Sonus Trim&Motor Kote)
Closer:
Exhaust tips in need of some love:
Done:
― Isaac Newton
Re: 2013 VW GOLF Sportline - 'Revival' + Pinnacle Black Label Coatings
WHEEL WORK
Wheels looked dirty but I wasn't expecting what I've found after washing.
BEFORE
AFTER Washing
To proceed, I've used the trusty Iron-X approach
It was clearly needed to get rid of this kind of contamination
After some dwell time, I gently agitate surface using many brushes
Slowly rinsing to get the most of my product until it's totally neutralized - but still works great as a 'strong soap'
Even after Iron decontamination, I decided to proceed with a tar removal process and also hand polish each wheel by hand using D300 and a MF towel / glove.
Not perfect, but much improved!
More on Prep.
Preparing this car for polishing took longer than the polishing (which was also intensive) itself. One important step of this preparation was getting rid of grime and tar attached to the whole under / side of the car.
Mother's R3 remover was very useful in the process:
However, my trusty 3M Citrus remover was better suited for more contaminated areas:
3M Citrus in action (it may show white when in contact with water
WASHING
After getting rid of all tar I could I detailed emblems, used brushes everywhere they fitted for a detailed wash then foamed the car using a mixture of Meguiar's Hyper Wash added with CG Bug / Tar Wash.
Definitively one of the easiest ways of making any car 'Dripping Wet' looking, no!?
No time to waste, after conventional washing, it was time for decontaminating the paint.
PAINT DECONTAMINATION
After washing it was clear most of dirt on this car was embedded, heavily attached to the finish.
Without thinking twice, an Iron-X shoot to help me clearing the path for the polishing step:
Product started reacting immediately after application
After some dwell time, it's easier to spot the degree of contamination I was facing:
On the Hood:
After removing Iron contamination, I did a tar removal step followed by Claying. For the claying step, I relied on CarPro Towel.
Overspray:
50/50 of claying for overspray removal (traced tape line for better visualization)
CarPro Spotless was also used both on glass and mirrors to get rid of water spots.
BEFORE
AFTER
POLISHING PROCEDURE
Some pictures shown for before are from the initial inspection (the car as it arrives)
Deep Swirls and Scratches
Take a look how scratched the paint was:
TEST SPOT
After detailing, cleaning and decontaminating the car, I was ready to start the polishing step. Like any 'conventional work day' I've grabbed first the 3401s, Menzernas and Foam Pads.
And even knowing it wouldn't be enough, I've started as low as a white pad and SF4000, a finishing polish. This approach helps me understanding better the paint I'll be working.
Spread the polish:
Work it to a thin film:
Remove residue using a quality MF Towel
And this is what I mean by quality MF Towel!
Inspect your results - few to no improvement:
After my test the first thing that came to my mind was 'WOOL + Heavy Cutting Polish'. However, I decided to step up slowly to meet the paint a bit more. FG400 + Orange Cutting Foam Pad
As expected, few to no improvement again.
One more step up, now to a Microfiber Pad and FG400:
Which showed not sufficient as well. That fact gave me enough confidence to grab Meguiar's M100 compound to achieve the results I was willing to get.
Rupes System is all about 'color matching' compounds and pads, right? hehe
― Isaac Newton
And that did the trick!
The results shown above are right after the compounding step. M100 truly lives the hype of cutting fast without hazing or dulling the finish. However, everything was polished via Flex afterwards to get an even finish - some parts received FG400@orange + SF4000@white, while other parts received just SF4000@white after the compounding step.
Only the strongest remained (after 1 compounding step):
After my 3-step approach, those RIDS ended up like this:
And we kept moving!
BEFORE
AFTERs
HOOD
BEFORE
AFTERs
BEFORE
AFTER
BEFORE
AFTERs
BEFORE
AFTERs
This defect was concerning my customer so I did my best to at least hide it to the extent I could.
BEFORE
AFTER Garage Lighting
AFTER Sunlight
MORE DETAILS
All handles worked by hand using a MF applicator and M100, followed by SF4000
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
Front Grille was also dulled and thrashed, my best will was to make it look improved. I've used PF2500@white pad followed by SF4000@gray finishing pad
BEFORE
AFTER
LAMPS
Sorry for the headlamp pictures, before (pass. side), after (driv. side). I couldn't find the correspondent pictures so they are here just to tell I've also worked improvements on headlamps.
BEFORE Pass. Side
AFTER Driver's Side
The tail lamps were also thrashed and although achieving much improvement I couldn't get rid of all defects and holograms. After correction via polishing they were finished as fine as a LC red finishing pad.
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
BEFORE
AFTER
Finally I got the whole car polished, washed again and coated with Pinnacle Black Label Surface, Paint, Glass and Wheel coatings, whetter they fitted.
― Isaac Newton
Wow...very Impressive work and detail!!!
That silver lady turn out to be the most elegance at show!!!
I wouldn't hesitate to roll in there
That is some extremely nice work there. Excellent results and amazing work with putting it all together. Very impressive!!
How many hours did it take you overall to complete that transformation?
Fantastic job! Very detailed. How long did interior and exterior take to do?
There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
Your work is incredible. You really put the "detail" in detailing
Great work! Excellent attention to the details and you show some great passion into your work, keep it up.
By Grifffx4 in forum Auto Detailing 101
Last Post: 04-11-2018, 03:49 PM
By Tato in forum Show N' Shine
Last Post: 08-24-2014, 10:08 AM
Last Post: 06-30-2014, 07:05 AM
By knucky in forum Show N' Shine
Last Post: 06-23-2014, 08:11 AM
By Dr_Pain in forum Show N' Shine
Last Post: 06-05-2014, 06:30 PM
