Thanks for sharing your thoughts. Since I'm newbie I wanted to use ticker pads to avoid paint scratching. Lake Country also offer 5.5" pads however they are thinner than 6.5".
What about chemicalguys black optics microfiber pads? Did you have any experience with this product?
6.5" LC pads on the Bigfoot will make the polisher vibrate, become unbalanced and cause premature bearing wear. Thinner pads will not result in paint scratching. The Rupes pads and LC HD Orbitals work on the Rupes as they designed for it.
Do a free air spin test on speed 6 with a variety of pads and you will realise what I'm talking about.
it's best to use the right backing plate to accommodate the hook & loop on the pad. using a backing plate too small will lead to the cookie cutter effect when pressure is applied to the pad around the edge of the backing plate...
My friend there are certain limitations, but I think you will be absolutely fine with your situation. As long as the pads witdth exceeds the plate you won't cause any damage. Good luck.
Peace,
Darrin
I disagree
I have found that if the BP is too small, the edge of the BP can cut into the Velcro backing of the pad and lead to premature failure of the pad
BP's are not terribly expensive for a standard DA
A properly sized BP will make your polishing more efficient and in my opinion is a good investment
