Re: Rupes 21 polisher, ISSUE!!!!!!!!?????????
I have the Rupes 15 polisher and I also noticed some black flecks when I first used it. It cleared up rather quickly and has been fine since. I would say by about halfway through the first car it stopped. I did not do the KB washer modification that many here recommend. I found that using good technique and absorbing the learning curve on the Rupes machine was all that was needed. So far I don't feel it is necessary.
The same thing happened to me the first time I used my Rupes 21. I also thought it was just some sort of odd break in routine. Come to find out the rubber shroud was actually catching on the backing plate and bending completely over and snapping flat with every rotation. This was causing chunks of rubber to fly off the shroud as the machine was in use.
In order to fix this problem I placed 2x 8mm washers between the backing plate and the spindle. This gave the plate enough clearance so it was no longer contacting the rubber shroud. The machine also works better with the washer mod installed.
Sent from my N9810 using AG Online
I polished out a GTI this past weekend and who whole time while doing the car I had that issue. seems to clear up a little bit towards the end of the job. but still saw the black specs of rubber....
Still unsure what I want to do about it. maybe do another 1 or 2 cars.... if still have the issue may have to do the mod... Wish rubes would have corrected this when in the R and D phase.
I'll have to take a picture of mine. The rubber shroud was literally getting torn apart from being bent into/under the backing plate with each rotation. After installing the washer mod I've used it daily and have had no issues.
The washer mod has been very very good 2 me.
I had the same thing happen to me. This has also happened to several local detailers I know. It eventually went away after polishing test panels with it.
I don't run the machine with washers btw.
You can also razor blade the shroud for clearance or just space it out with the washer....or sell the poor machine to me.
Ever since Kevin Brown introduced the washer mod there has been a split in opinions. From reading the comments from the factory reps and meeting the techs at SEMA for me it came down to personal preference. Rupes will tell you all over the world the 21 is used without a washer mod. Kevin goes into great detail explaining exactly his ideas behind his " mod ". I have tried it both ways multiple times and have stuck with using the washer which IMO fits my style of correcting paint. So to answer those that think Rupes didn't do there homework , they have. I believe the 21 to be a quality machine. I just happen to like it with the " mod " . I own three Rupes machines and soon will pull the trigger on my fourth.
I have the same issue with my Rupes 15. I only have a single 8 mm washer installed.
I was trying to check the alignment of the washer and possibly add one more but I managed to strip the head with my cheap HF Allen socket!
So I'm gonna live with it for now or attempt to file the shroud down a hair if it doesn't break in after a few more hours.
I've been running my Rupes 21 with the washer mod for 27 months now and never had a single issue. I did try polishing a few panels when I first got the tool without the washer, and the tool worked fine but the pad didn't spin freely, which is an issue for me when blowing out pads. The addition of the washer gives more correction power since it's not being slowed by the shroud and I have not looked back once since adding the washer. I really don't know why people make such a big deal about adding a washer either??? It takes 30 second and simply opens the gap between the plate and the shroud....
By mrasmussen in forum Ask your detailing questions!
Last Post: 06-15-2020, 09:25 AM
By brunoranger in forum Auto Detailing 101
Last Post: 04-11-2019, 05:54 PM
By joleyred in forum Auto Detailing 101
Last Post: 05-27-2018, 10:18 PM
Last Post: 01-10-2017, 11:26 AM
By choijw2 in forum Auto Detailing 101
Last Post: 02-23-2016, 12:38 PM
