Results 21 to 30 of 35
  1. #21
    Nov 2009
    Pasadena, CA
    12,615
    Re: For All You Rupes Lovers vs Flex
    Quote Originally Posted by Dave.0 View Post
    and the one I like the most and always use is the 3rd gen Griots Garage DA with the Powerful 7-Amp, 850-Watt Motor which has tons of TQ to keep pads spinning even at low speeds with a little pressure.
    I just ordered a GG 6" today for use with smaller pads(3"-4") and to correct soft paint with 5.5" pads.
    '03 Corvette Z06
  2. #22
    Super Member VISITOR's Avatar
    May 2007
    9,750
    For me I have had a Flex, Rupes, 2 different PC's and the one I like the most and always use is the 3rd gen Griots Garage DA with the Powerful 7-Amp, 850-Watt Motor which has tons of TQ to keep pads spinning even at low speeds with a little pressure.
    agreed, i have the 2nd gen GG6 and even on speed 4 you can't bog it down unless you put crazy/ridiculous amounts of pressure. it's the Little BOSS (name given by joe@nextleveldetail)...
  3. #23
    Apr 2012
    7,494
    Have fun with that.
    It's super tippy and will rattle your wrist to death in no time at all.
    Ask me how I know that.
    I ran my PC with a 3" bp, GG6 with 3" bp and my Rupes Mini side by side test about a year and a half ago all with B & S 3" and 4" pads. I used a 3.5" LC Backing plate on the 4" pads and 3" LC BP on the 3" pads for the test.
    Obvioulsy I'd take the Mini all day long.
    But given that, without making the investment in the Mini, between the other two I would take the PC with the 3"-4" set up all day long over the GG6. PC was much more stable and wayyyy less vibration.
    Also, I preferred the 3.5" BP with 4" pads as you could actually cut into areas like below the side mirrors without as much risk of the machine banging off of some sensitve parts and damaging something.
    2019 Nissan Rogue SL
  4. #24
    Jul 2016
    3,328
    Quote Originally Posted by don40vette View Post
    Many of you will admit that the Rupes stalls but there are just as many that say it outperforms the Flex 3401 and even others that say it does better than a rotary.
    [b]Lets put the Rupes vs Flex in a car on a drag strip. The Rupes stalling has no chance. I see it the same in polishing.[b]
    Cry away Rupes lovers.
    This will be great.
    ok but they are not cars in a drag strip, it's in no way what so ever the same thing
  5. #25
    May 2007
    9,750
    Quote Originally Posted by custmsprty View Post
    Have fun with that.
    i disagree. the GG6 (2ng gen) vibrates less (smoother) then my PC7424 and also is more comfortable to hold compared to the PC as well. also, the current version (3rd gen) is more ergonomic too.. heck, even the junkman noticed it too and it was his first time using the current GG6 even though its with a bigger pad. My PC us collecting dust its uncomfortable to use with any size pad...
  6. #26
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,019
    Have fun with that.
    Also the spindle housing on the GG6 is bigger than the 7424xp. The 7424xp has a nice, compact housing, allowing for visibility with 3", and 4" pad set ups. That's one of the reasons I went with it over the GG6, or G110v2 (at the time).
    Just as with using 5.5" pads, 3.5", and 4" pads run smooth.
  7. #27
    Apr 2012
    7,494
    Yup, that metal shroud on the GG6 will play rough with anything that you bang it off of. It's an accident just waiting to happen. You ding it, you own it.
  8. #28
    Apr 2015
    PGH, PA
    1,482
    After spending more time with my Chinese 15mm(washer mod), I feel the correction power of the 3401 is overrated. It's still only an 8mm throw. On the flip side, it doesn't stop spinning which is awesome. They both have their pros and cons. I have both and will not sell either.
    and to add to this, adding more pressure doesn't always equate to faster correction...just means it wont stall or bog down...a free spin 8mm could have more rpm which would overtake a forced 8mm if it does in fact out rotate it and not stall(cant confirm as I haven't really played with 8mm)..
    all these machines are better over the others in certain situations, reasoning, they all have different faults and different pros..
    as for a response to try and relate to original analogy..
    drag strip..
    pad rotation is your revs
    stroke is your torque 8mm vs 12-15-21mm
    if you have more torque through your powerband...guess which wins at a drag strip?
    why do you think stroker builds typically beat hi rev motors of similar HP?
    why do you think forced induction beats up on naturally aspirated?...more working force/torque
    Boom goes the dynamite
    but even that doesn't really translate completely
    if you get better results with one machine over the other...that only proves you're more proficient with that particular machine
    as the saying goes, use what you like, use it often..and every tool has its place!
  9. #29
    Nov 2009
    Pasadena, CA
    12,615
    I've used a GG 6" with 3" & 4" pads and it was just fine. Went against the MINI because the GG gives me the option to use 5.5" pads when needed.
    '03 Corvette Z06
  10. #30
    Super Member HateSwirls's Avatar
    Jun 2013
    3,632
    Owning a detail shop you need many tools and products.
    That being said I first bought the Flex 3401 and knew right away it was a beast of a machine.
    For months I used it and always got great results but it took a toll on my elbow, not sure if it's because it rotates left or not.
    Then I bought the Rupes 15
    The 15mm is why it corrects so well, it's so freaking smooth to operate, even hours and hours of using it non stop.
    Bottom line ...
    You won't regret buying either one of them, both were game changes
    Sent from my iPad using Autogeekonline mobile app
    cajundetailingbykevin.com
    vpcajun@gmail.com
  1. Flex PE-8 Vs. Rupes TA50 Vs. Rupes de-nibber ?
    By cobraa in forum Auto Detailing Tools and Accessories
    Last Post: 06-20-2016, 02:00 PM
  2. Flex PE8 OR THE RUPES LHR 75E..
    By Duck_ in forum Auto Detailing Tools and Accessories
    Last Post: 12-05-2015, 04:34 PM
  3. Flex vs Rupes
    By Ramdallas in forum Flex Polishers
    Last Post: 01-31-2015, 04:34 PM
  4. Flex or Rupes?
    By parttimer in forum Auto Detailing 101
    Last Post: 09-18-2013, 04:02 PM
  5. Flex vs rupes go with flex my honest opinion
    By Wynex in forum Off-Topic
    Last Post: 07-15-2013, 03:35 PM
