Re: New iBrid owner frustrated....what am I doing wrong?
Originally Posted by DaveT435
Short neck is 560.00
Whoa! I didn't know it was way more than a 21MKll fully loaded + bag included Wow!
Sent from my iPhone
I agree on the main benefits.
Small size = great access and manuverability.
Battery power means no tether so can move about freely.
First time I used it on underside of trunk lid.
Primed blue pad like I normally would do and smeared around area.
Turned on in rotary mode and coated my neighbours rear window with sling (lol).
The trunk lid on the other hand polished up great (it had never been touched in 15 years-severe water spots).
There is no way I could have done this any other way.
How small of a trunk was it?
A few things to note, for what it's worth. A 7-inch pad has a surface area of (approx) 38.5 inches squared. A 1.2-inch pad has a surface area of 1.1 inches squared. In other words a 7-inch pad has 38 times, or 3800% larger.
This has a drastic effect when it comes to the amount of force the pad's can realistically be expected to handle... Force x unit area = pressure.
The biggest thing in getting the proper performance from the nano is random orbital mode is near-zero pressure. I am amazed at how many times I hand the polisher to somebody and they bare down on it... If the pad is (more than ever-so-slightly) compressed, you are adding too much pressure to the pad. The 2-inch pad has a surface area of 3.14 inches squared, and can - in theory - hand 3x's as much downward force, although it is still very very little compared to 7-inch pad.
So the first thing I would recommend is reducing pressure (likely).
The center or polishing area of the pad has to be flat to the surface. Relax your trigger hand and set the tool flat to the surface and use. People tend to over grip a DA and thus tilt the pad the further they move it away from their body.
As for sling, I would recommend following our priming procedure. Run at speed 3 using medium (relative, it is still very light) pressure in a small spot for 30-40 seconds using about half of 1 pea-sized drop. For reload use speed 4-5 and about 3/4's of a pea-sized drop max (maybe less).
We recommend using a polishing area size of an area about 6x the size of the pad (ish). This gives relatively the same results per speed setting, per tool, per pad size, per pad type per pad compound time. As the tool shrinks, so, of course- does the working area to keep results consistent. The Mark II tools will produce similar results using speed settings about 2 less than the other tools.
I hope this helps and makes you happy with your new polisher.
Thank you Todd! Totally makes sense. I had a feeling it was user error and no doubt use of the Flex is influencing my technique.
My next detail is in my garage awaiting a test come Saturday. I'll keep you posted.
It was the inside of the trunk side-not the outside.
Hi Todd,
I use the 1" rotary tool and no matter what get sling with the Nano 1" blue pads and blue polish.
We are not talking "pea size" drops, I'm talking 3 "smudges".
I notice not so much with the yellow pads and polish.
Is this because different type of foam?
I just ordered the Lake Country Hybrid 1" and 2" pads to try on my Ibrid, will post follow up when they arrive.
I will be producing a video in the next few days. I ran the pads today for the first time this afternoon. When I was at 3M for the previous 35 years and calling on paint departments throughout the US and Oh Canada we had a slightly different approach to buffing and polishing. I put my knowledge to the test and hope that you find the information helpful. I had no sling , not a bit. I did something that I have not seen covered in videos or text and it worked like a charm. Before I photograph or shoot a video I am going conduct another test. Then another. It will be worth the wait.
By Grifffx4 in forum Auto Detailing 101
Last Post: 04-09-2018, 08:59 AM
By sdguy55 in forum Wet-Sanding, Cutting & Buffing
Last Post: 08-07-2015, 12:45 PM
By DaBuss2014 in forum Auto Detailing 101
Last Post: 09-16-2014, 08:08 AM
By Kristopher1129 in forum Show N' Shine
Last Post: 01-12-2012, 11:27 PM
By ride5150 in forum How to make money detailing cars
Last Post: 06-08-2011, 02:48 PM
