Mark II Washer Mod Where To Get?
I've had my Rupes 21 MK II for a while now, was it supposed to come with a washer like the G21?
I didn't see one in the box, if not where can I pick one up from?
Thanks
Re: Mark II Washer Mod Where To Get?
Rupes does not supply or recommend the use of the washer mod. I believe you need an 8mm washer if you really need it. Kevin Brown has a video on how to make your own for the Mark 1. Try Google.
M8 washer will do the trick.
Yeah I know Rupes' stance on it and I think it's silly. I've been using the Flex for 5 years now and thought giving the Mark II 21 a try. So far, I'm not really impressed. The Flex corrects better but I'm not fatigued after 10-20 hour detail using the Rupes. I had hoped by using the washer mod I can bring it closer to Flex correcting level, without the fatigue incorporated using the Flex.
Sweet, M8 washer, any modifications required to it? Thanks.
No mods needed.
Originally Posted by WRAPT C5Z06
No mods needed.
Yeah, what's the point?
How much power is enough? Might as well go with a rotary.
Not too mention the more aggressively you grind away the more clear or paint you remove. Least is better IMHO.
2019 Nissan Rogue SL
The first question that comes to mind is "WHY?"
The only reason anyone ever needed a washer mod was to maintain pad rotation in areas where it would otherwise stall and they couldn't compensate with technique. Have you found that you're experiencing pad stall with the Mark II? If so what speed? We recommend running the tool at speed 3-4 and that gives you 2-3 increased speeds to compensate for stall should you encounter it.
Also worth mentioning in regards to those saying "M8 washer" - we've had a rash of tools being returned for repairs because users have imbalanced backing plates, severe wobble, or simply cannot get the plate off of the tool. When they arrive in most of these cases it turns out the user has placed an UNMODIFIED ROUND WASHER on the tool. The actual washer mod developed by Kevin Brown is a washer that has been cut down to match the pin and fit into the recess on the stock backing plate, not just a simple M8 washer.
Note the shape of the recess in the backing plate:
I never had any problems with my 21 mkii. Whenever I noticed the pad begin to stall on a curve Id adjust the angle at which i approached a curve and the pad would maintain its rotation. Just takes some practice on technique.
I totally agree on this. Technique adjustment is all that's needed to avoid pad stalling. Of course this won't work for very aggressive curves... The mini 75E or other 3" setups will be needed for that. Even if the Mk II can power through panels aggressive curves, I honestly don't think it will be doing much polishing since the pad won't make full contact anyway... I mentioned all these in my Rupes vs Boss polisher review too.
Last Post: 08-14-2016, 12:59 PM
By fotomatt1 in forum Products Guides
Last Post: 08-12-2016, 09:03 AM
By alegend in forum RUPES BigFoot Oribital Polishers
Last Post: 05-15-2016, 08:21 AM
By nova power in forum RUPES BigFoot Oribital Polishers
Last Post: 01-18-2016, 07:31 PM
By SonOfOC in forum RUPES BigFoot Oribital Polishers
Last Post: 12-25-2015, 04:20 PM
