Re: Mark II Washer Mod Where To Get?
Dylan, I've been using the 21 on flat or slightly curved panels and I have the Flex setup for deep curves. I use speed 3-4, sometimes 5 but I find with 5 I get a lot of dusting and the polishing oils evaporate quicker from the heat.
Since getting the Rupes, a normal two step or multi-step paint correction has turned into 1/4 - 1/2 additional steps in order to get the correction I'm looking for over the Flex VRG. I feel that if I was able to put down a smidge more pressure on the 21, I could fill that very small correctional gap because right now, if I apply pressure on the 21 it does bog down very slightly.
I've already decided 110% on the washer mod. Just need to know where to get it now.
Kevin just hooked me up with one a while back with one of my orders
I don't use it all the time but when I do the machine does appear to feel smoother but the panel doesn't get any warmer.
When you get used to forced rotation, you become spoiled. Most who don't like the 3401 don't deny its performance, but the way it fights you when polishing. MUCH more energy needed for sure, but, it's well worth it to me. It really comes down to user preference.
Originally Posted by Dylan@RUPES
The first question that comes to mind is "WHY?"
The only reason anyone ever needed a washer mod was to maintain pad rotation in areas where it would otherwise stall and they couldn't compensate with technique. Have you found that you're experiencing pad stall with the Mark II? If so what speed? We recommend running the tool at speed 3-4 and that gives you 2-3 increased speeds to compensate for stall should you encounter it.
Also worth mentioning in regards to those saying "M8 washer" - we've had a rash of tools being returned for repairs because users have imbalanced backing plates, severe wobble, or simply cannot get the plate off of the tool. When they arrive in most of these cases it turns out the user has placed an UNMODIFIED ROUND WASHER on the tool. The actual washer mod developed by Kevin Brown is a washer that has been cut down to match the pin and fit into the recess on the stock backing plate, not just a simple M8 washer.
Note the shape of the recess in the backing plate:
Are you saying they literally just stuck a round washer between the backing plate and the machine (that's what it looks like in the photo)? If so, wow. Maybe there needs to be a sticky on the washer mod to help prevent others from mistakenly ruining their machines.
How did they take it when you told them, sorry, but you ruined the machine?
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
I hope Rupes returned their machined with "user error" as reason for not replacing. We used to say "headspace and timing" problems in the military. Just say no to washer modding unless you are ready to void any warranty. I sure Rupes fixed the machines, but they shouldn't have. You can't fix stupid.
Last Post: 08-14-2016, 12:59 PM
By fotomatt1 in forum Products Guides
Last Post: 08-12-2016, 09:03 AM
By alegend in forum RUPES BigFoot Oribital Polishers
Last Post: 05-15-2016, 08:21 AM
By nova power in forum RUPES BigFoot Oribital Polishers
Last Post: 01-18-2016, 07:31 PM
By SonOfOC in forum RUPES BigFoot Oribital Polishers
Last Post: 12-25-2015, 04:20 PM
