Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 81
  1. #21
    SELF BANNED ASPHALT ROCKET's Avatar
    Mar 2006
    Northern Virginia
    2,872
    Re: 4 part prosses still has swirls?
    Here just relax and we I will get you straightened out. The wool cuts better than the yellow but leaves a better finish because it levels the paint better which in turn will make it easier to remove the marring from the wool.
    I know you didn't say you were not filling anything, it is the polish that is filling. The 3M swirl remover is widely known as a filler not a true swirl remover. The only true swirl remover that 3M has is its Ultrafina/Ultrafine. When you are polishing and do not remove all the swirls and wipe away the polish and not use an IPA wipedown the polish will "fill" the swirls/marring. So when you jumped to the gray pad it is not strong enough to remove the larger swirls/marring that the yellow pad induced so all it did was remove the polish that "filled" in the swrils/marring. This is why you thought the gray pad was the problem. I know if you were to do and IPA wipedown before using your gray pad all the swirls would have re-appered and you would have understood what I was trying to say. In the detailing world no matter if the polish says it does not fill but if it does not remove the swirls completely we call it filling them in-i.e fills. I hope this helps a little better. If not ask a few more questions and I will give you the answers.
  2. #22
    Senior Member unclestu's Avatar
    Jun 2009
    483
    Quote Originally Posted by ASPHALT ROCKET View Post
    Hey Dana,
    In this situation would you have gone to an orange pad after the yellow instead of the gray pad?.
    This is a great example of (as you always said) how important it is to do an IPA after each stage of polishing.
    [SIGWe PIC][/SIGPIC]
    We are what we repeatedly do. Excellence, therefore, is not an act, but a habit. -Aristotle
    MAY THE SHINE BE WITH YOU
  3. #23
    Senior Member DLB's Avatar
    Jul 2009
    Ringgold, GA
    1,211
    Quote Originally Posted by unclestu View Post
    Hey Dana,
    I say it is a great example of how important it is to do a test spot.
    DLB
  4. #24
    Aug 2008
    1,715
    What polisher are you using?
    08 Subaru WRX
  5. #25
    Mar 2006
    Northern Virginia
    2,872
    Hey Dana,
    UncleStu you are correct, yes an orange pad after wool, then white, then a finishing pad. It was late and I overlooked that. I apologize to the OP for forgetting that step.
    Also this would be a perfect example of why you do an IPA wipedown after each step.
  6. #26
    Senior Member SRHTX's Avatar
    Mar 2009
    Harlingen, TX
    1,664
    Cool Re: 4 part prosses still has swirls?
    I wonder what she has done today............
    The Auto Spa of the Rio Grande Valley
    Stephen R. Hollon, Jr / (956) 357-7696 – Cell/Text / srhtx@yahoo.com
  7. #27
    Senior Member Lasthope05's Avatar
    Aug 2007
    Philadelphia, PA
    1,113
    ok i am using 3m compound with 3m wool head then a yellow foam head, i then used perfect it polish for dark with 3m gray head, then i used finesse it finishing polish with blue polish pad. but i STILL have swirl marks from the gray pad.
    Just to everybody knows. She said she is using the 3M pad system. Not the Lake Country Pads. Dont get confused as I see so many of you are.
    So she has:
    3m wool
    3m black/gray polishing
    3m blue pad(ultrafina)
    Its all speculation until she comes back in and verifies. I for one have a set of these pads and have no problem going with 3m wool straight to 3m black foam at all. I think you're not breaking down the polishing long enough, or you could be over working and dry polishing.
    Just because a polish contains fillers doesnt mean it wont correct. Take a look at the old Megs twins 83/80. They are heavy in oils that fill but the abrasives in them also correct the paint at the same time. Its mostly technique not product.
  8. #28
    Aug 2008
    1,715
    Are you working the polishes down long enough so the polish fully breaks down?
    08 Subaru WRX
  9. #29
    Nov 2009
    Buffing with a mismatched system can be a frustrating experience. 3M offers a new simpified system. I have used it with excellent results. I went on to their website to get you details.
    3Mâ„¢ Perfect-Itâ„¢ Paint Finishing System - A fast and effective way to produce a swirl-free automotive finish US 3M
    You would be interested in steps 3-5. It is key to use the correct pad with the corresponding compound.
  10. #30
    Mar 2009
    Harlingen, TX
    1,664
    Well, I know where she went the other day. She is waiting for me to arrive in San Antonio, TX next week. I also know what she has purchased, however, it's not for this problem. Something that she saw used and loved it. She was given some very good coaching about her vehicle.
  1. Replies: 55
    Last Post: 07-09-2016, 10:01 PM
  2. Replies: 13
    Last Post: 10-29-2014, 06:21 AM
  3. Is my wash process still causing swirls?
    By olenderc in forum Auto Detailing 101
    Last Post: 09-18-2014, 11:32 PM
  4. The difference between Rotary Buffer Swirls, Cobweb Swirls, Micro-Marring, DA Haze & Tick Marks
    By Mike Phillips in forum Hot topics & Frequently Asked Questions
    Last Post: 05-29-2014, 07:48 AM
  5. 23 YEAR OLD swirls on top of swirls - 88' Red Honda Civic pix/vids
    By Wills.WindowsAndWheels in forum Show N' Shine
    Last Post: 11-24-2011, 06:25 PM
» January 2018
28 29 30 31 123
