Re: Menzerna 85RD as a Paint Cleaner?
85RD has pretty much NO cutting power.
However, if the finish is already in great shape and you want to give it a light polish before waxing/sealing, 85RD would be just fine - especially if you're claying.
Great idea I can use the 85RD as a light polish maybe once or twice per year just to keep the surface of the paint clean and remove old wax or sealant, then apply a new coat of wax/sealant. Then for the heavy detailing (once per year) the WG duo follow by 85Rd to "jewel" the paint. Thanks
You got it!
If I'm using Meg 105(orange pad)/205(white pad) for paint correction, would using 205 with a gray pad yield the same results as jeweling with the 85RD? I just don't want to have too many products but need enough to do the paint correction.
SELF BANNED
They would be kinda close but I always use 85rd or Ultrafina after 205. 205 just doesn't have what 85rd or Ultrafina has to offer as far as depth, clarity, and gloss.
You won't get the SAME results - 205 is certainly not a jeweling polish as it has a decent amount of cut for a finishing polish. But, you will achieve a FINER finish with the gray pad as opposed to the white pad.
With that said, I've found that going straight from 105/orange to 205/gray is good enough to call it a day in most all cases. Following with something like 85RD or Ultrafina is entirely optional - to some it's worth it, to some it's not. On certain paints, one may not even notice a difference, while on other paints it may be night and day. Just remember that everything is pretty subjective in the world of detailing and sometimes you have to test certain things to find what achieves the best results.
Cool, it also may be different based on personal taste and the color of the paint. I have both older black cars and brand new white and silver cars. I know that finishing with 85RD will make the paint LSP ready without the need of ZAIO (I'll be using Z2 Pro). I've seen several professional detailers on these forums going straight to Z2 or Z5 right after 205 on white. So I guess it's all about trial and error.
I'm very interested to see how the 205 and 85RD compare when used on the newer scratch free ceramic clears.
That’s why I will like to ask. If the Menz. 85RD can be used as a Paint Cleaner ?
Will this work or the cutting power of the M85RD is not that aggressive? Let me know your experience with this product or comments?
Depending on the finish, 85RD will work great as a "paint cleaner" in the sence that it can remove a very respectable amount of defects/swirls/micromarring at the same time creating an incredible amount of gloss. It's my go-to polish on soft paints like Porsche, Bentley & Rolls Royce, Toyota/Lexus & Rovers. I just tried using 85RD on a black Nissan GTR and it worked really well.
I think "NO cutting power" is a gross understatement. Next chance you get try it again and you might be really surprised. I believe on some paints, it would have no problem removing 2000 grit defects.
Make sure you do atleast 1-2 good alcohol wipe downs before applying Zaino. I've personally witnessed bonding problems with the oils that Menzerna leaves behind on the finish. I always do a Dawn wash and a couple wipedowns myself just to be on the safe side no matter what polish I use prior to sealing the paint.
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
I'm curious.......you said you've witnessed bonding problems with the oils that Menzerna leaves behind.........how do you know when you have a bonding problem? What does that look like?
By 05RLS2 in forum Auto Detailing 101
Last Post: 06-11-2011, 12:08 AM
By DiPaoro in forum Auto Detailing Tools and Accessories
Last Post: 05-23-2010, 11:24 AM
By jbnery6465 in forum Auto Detailing 101
Last Post: 01-05-2010, 02:59 PM
By Hashimon in forum Auto Detailing 101
Last Post: 02-27-2009, 09:21 PM
By nrengle in forum Auto Detailing 101
Last Post: 10-03-2008, 05:37 PM
