XMT 360 vs D151 PRC
Hey guys. I did a quick video comparing XMT 360 and Meg's D151 PRC. These are 2 great All-In-One (AIO) products. Both are easy to use and can give great results in only one step.
XMT 360 vs D151 PRC - YouTube
I plan to update this thread periodically and see which product lasts the longest.
Feel free to share your experiences, pictures, videos, questions or opinions with either of these products in the comments section. Thanks for looking!
Re: XMT 360 vs D151 PRC
Nice product comparison...Good job!!
Interesting! Thanks for taking the time to share
Looking forward to using the 151 I just purchased. Did you follow up with any lighter pads after the orange?
Cool! I was wondering if you were doing a review or not. I still haven't had a chance to try the D151 yet. Been too busy with "domestic" duties
Thank you for the review & video.
Interesting to see how quicker 360 sheds water. Look wise, which do you prefer?
I have a 16oz sample of D151 which I use periodically (with a polishing pal) to remove minor scratches. It does an excellent job on the soft Subaru paint.
Thank you! Let me know if there is anything else you would like to see in this comparison!
Originally Posted by BobbyG
Nice comparison video Nicholas!
I've always liked Meguiar's D151 and use it with both my rotary and dual action polishers. For some reason I achieve better results using a rotary and foam pad. I'm not sure if the abrasive is designed for both or possibly the way I use it...
Either way it works but now it looks like I may order a sample of Pinnacle's XMT 360...
Thanks Bobby! I really like D151 with a rotary too. Although... even with a finishing pad I've seen it leave holograms so I always finish out with a DA for the perfect shine!
The XMT 360 doesn't seem to have as much correction ability as D151 but for really slight swirl marks or type 1-2 water spots it does a great job.
Thanks for looking!
For this test I used only 1 pad, 1-step for each product. D151 was worked in 2 heavy passes and 1 light pass. XMT 360 worked for about 3 heavy passes and 2 light passes. This is due to the fact that XMT 360 uses diminishing abrasives that are supposed to leave almost no residue to wipe away.
I initially intended to work them both the same amount of time but XMT, due to its abrasive technology, requires it to be worked longer than D151 (which uses SMAT abrasive tech).
Thanks again for the sample!!! You rock!
Thanks for looking! To me they both look exactly the same. I could not tell the difference at all when I was finished. The only time I can see a difference between the two is when there is water on the paint.
Originally Posted by CM8 6MT
Subscribed!
Thanks! Stay tuned for ongoing updates!
Nice video Nick. Looking forward to the updates as I use D151 a lot and have had great success with it.
By 96z28 in forum Auto Detailing 101
Last Post: 06-09-2014, 10:08 AM
By snellvilleauto in forum Auto Detailing 101
Last Post: 04-13-2012, 11:51 AM
By WindyCity in forum Products Guides
Last Post: 07-23-2011, 11:44 PM
Last Post: 04-18-2011, 09:36 AM
Last Post: 03-26-2011, 12:09 AM
