McKee's 37 Product Support
Two New CarPro Products! Iron X Paste & Tar X
The CarPro line of car care is quickly expanding. With the huge success and popularity of Cquartz, an anti-static, weather-resistant nano coating, CarPro continues to introduce products that change the way we look at car care. Besides the durable protection and crystal-like shine of Cquartz, CarPro revolutionized the way we protect and beautify plastic and rubber surfaces with PERL. Cquartz and PERL are just a few of the state-of-the-art car care products that have given CarPro the reputation of being an innovator in the industry. CarPro has a loyal following, and with the constant improvements being made to current formulas along with the introduction of new products that make the art of detailing easier, CarPro is on a roll that is envied by most.
Iron X and Iron X Soap Gel changed the way we look at paint decontamination. Iron X is an iron remover that opens up the pores in the paint making the removal of ferrous iron particles effortless. Iron X and Iron X Soap Gel enable you to make your paint squeaky clean before applying your favorite wax or sealant.
With the introduction of Iron X Paste, you now have the ability to remove embedded iron particles in more concentrated areas because of the thick viscosity that cleans to the surface, allowing the product to work longer. When it comes time to remove stubborn iron deposits on wheels and paint, Iron X Paste will be your new go-to solution.
Removing tar and adhesive on automotive finishes is never a fun task. You're often faced with products where you aren't sure if they're safe on your delicate clear coat. The product may say clear coat safe, but if it has hundreds of other uses including removing oil stains from the surface of a driveway, are you sure you want to use it on your paint? I didn't think so.
If you're a professional detailer, you're often faced with this issue. Well the solution has arrived with Tar X by CarPro. Tar X is a glow-in-the-dark bug, tar, and adhesive remover that's clear coat safe. Tar X contains no harsh chemical solvents that will harm your delicate clear coat finish. Like several other CarPro products, Tar X changes color to show that it's working. With Tar X by CarPro, you can be sure that the surface you're working on is free of bugs, tar, and adhesive. Give your vehicle the best with Tar X.
Tar X
Iron X Paste
Nick, is there going to be any bigger bottles of Tar X?
Super Moderator
Re: Two New CarPro Products! Iron X Paste & Tar X
Yes there will be.
Awesome thanks for the quick reply.
Since my order hasn't shipped yet time to give you guys a phone call.
Let's say you use IronX first. After, would TarX remove the same things that you would remove with clay? Basically, if you IronX'd, then TarX'd, is there still a need to clay?
Excellent question, i'd like to know the answer too.
Philippe
Thanks.
There's not many things in detailing that I don't enjoy to do, but claying is one of them. I would assume, even after these 2 steps, they'll probably still suggest claying, but we'll wait for an answer.
I find it strange that I haven't seen Avi on the forums for sometime now. Must be a busy man but I'm sure he'll chime in like he always does with an answer for all of us.
I'm going to go out on a limb here but I'm sure he'll still suggest that we clay after we Iron X and Tar X the car.
TarX in action, a video that's on AG's website. Warning you'll want to turn down the volume
‪TAR X.wmv‬‏ - YouTube
Hi All
ill try to answer you in the best true way, i think that after these both de-con you will remove 90% of contamination from surface. i dont want to say 100% since there always could be other dirt/sand/dust baked in the clearcoat
the best way to check if you need to clay after is to test with cellophane nylon , same as wraped the cigarette boxes. passing it on the car paint with your two fingers inside of it
Avi
By jaymac15 in forum Product Reviews
Last Post: 12-04-2016, 02:41 PM
By Rod73 in forum Product Reviews
Last Post: 08-01-2015, 03:41 PM
By The Critic in forum Auto Detailing 101
Last Post: 10-14-2013, 02:22 AM
Last Post: 02-15-2013, 05:14 PM
By CEE DOG in forum Product Reviews
Last Post: 01-05-2012, 09:03 AM
