105/205 & Hydro pads
I think I read somewhere 105/205 are SMAT products and I thought I came across a thread stating the hydro pads work better with DAT products.
Can someone give me some feedback on this combo. Yes/no
Or should I pull the trigger on 400/4000? I really would like to finish at least half my Megs stuff.
I'll be working on a black sequoia btw
Quote:
Originally Posted by mcate
Black isn't a color, it's a part time job.
Re: 105/205 & Hydro pads
I would say it's more like DAT works better with HT or flat pads. They should be fine with M105/205. I use my ccs pads with M105/205 only because I am trying to get rid of them and then will probably only use flat pads for everything.
SMAT --> CCS or flat
DAT --> flat
2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
DAT --> flat
These are the hydro thin pads I'm referring too. Sorry should have mentioned that.
I'm in the same boat trying to finish up 105/205 I don't believe in wasting products unless they don't perform and we all know 105/205 does!!
I just wanted some real time feedback with this combo...
As I said, you will be fine with the hydrotech pads and M105/205. If anything you might see a little more bite/work time with the closed cell hydrotechs because less product will be absorbed into the pad. I just switched to HT's for my sealant pads because it seems so much gets wasted into the pad with open cell flat and ccs pads.
I use Hydrotech pads for any polish. I like M205 on Tangerine.
My sequioa is in decent shape, I'm really hoping to start with 205/tangerine.
Thanks to both of you for your feedback
You bet. Hope you'll "show & shine" after you get 'er done.
I personally prefer to use a ccs or flat pad instead of HT, really don`t think this pads can perform better than the 2 first mentioned above. I gave them a few try but not satisfied. 105/205 is a good combo to go with for sure!!
I think I've found a home with Hex Logic's pads. Particularly with a two step, I like their open cell pads, the green cutting/polishing, and blue polishing/finishing.
One of the nice features of the open celled pads for me is that I use a lot less product, and the pad itself has some bite to it. If I need anything more agrees I've than the green Hex Logic, I move over to the Rupes microfiber discs.
Another great pad is Lake Country's pink, and green ccs pads.
By solman in forum Auto Detailing 101
Last Post: 08-21-2014, 03:56 AM
By Ncs0816 in forum Wool & Foam Buffing Pads
Last Post: 10-04-2013, 08:38 PM
By david11g35 in forum Auto Detailing 101
Last Post: 03-20-2012, 08:14 PM
By pcw25 in forum Auto Detailing 101
Last Post: 02-15-2012, 09:19 PM
By fredcandetail in forum Auto Detailing 101
Last Post: 05-20-2011, 09:41 AM
