Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Jul 2013
    Learning with mf pads on soft honda paint
    Any advice for learning paint correction on soft honda paint with meguiars mf system? Does any one have experience correcting soft paint with mf pads?
    Regular Member RawDetail's Avatar
    Feb 2014
    119
    Re: Learning with mf pads on soft honda paint
    I do it every day and it's super easy with the Megs MF pads . Go ahead and do a test spot first, you'll see how it comes out from there.
    Harrisonburg's #1 Recommended Detailer - RawDetail.com - DetalingAddict.com
    Feb 2011
    Minot, ND
    12,365
    Quote Originally Posted by Drew.culp View Post
    On soft Honda paint, I would first try a test spot with D302 on a finishing mf pad to see where that gets you. You may not even need to use D300 with a mf cutting pad.
    Jul 2013
    How mf pads do I need to finish a civic?
    Best way to clean on the fly and clean the mf pads?
    Feb 2011
    Minot, ND
    12,365
    I would grab 2 two packs for a total of four pads. If you are making the initial purchase, I would grab both the cutting and finishing mf pads in case you need to get more aggressive.
    Best way to clean mf pads is with an air chuck. If you dont have one of these a pad brush will suffice.
    Here is some reading on effectively using Meguiar's mf system.
    How to use Meguiar's DA Microfiber correction - Autopia Forums - Auto Detailing & Car Care Discussion Forum
    http://www.autogeekonline.net/forum/...er-system.html
    Super Member EVOlved's Avatar
    Oct 2013
    Queens, NY
    1,128
    You already bought the system?? If so then I would follow the previous advice do a test spot with the least aggressive route first.
    Jul 2013
    I have not purchased it yet. Was hoping the finishing mf pad would be my first and only test. But know of a few spots too that might need the cutting pad as well.
    Is the d300 and d302 the way to go or do you guys recommend just using m105 and m205? I have read that some recommend those.
    Feb 2011
    Minot, ND
    12,365
    Your better off with D300 and D302 as these were designed for use on the mf pads. Not saying you cant use M105 and M205, but your compounding and polishing experience will be better off with products designed for it's intended use.
    Jul 2013
    Ok I'll just wait for a sale and get some new toys.
    I have read plenty of good things of the mf system.
  10. #10
    Super Member wdmaccord's Avatar
    Jun 2013
    West Des Moines, IA
    1,278
    You don't need to use the MF system on soft Honda paint if you don't want to. I've been able to get very nasty swirled and marred up soft Honda paint to near 95% with Megs UC on an orange light cutting CCS pad with a GG6 with 6-8 passes. That many passes does take quite a bit of time with slow arm speed, so if you wanted to speed up the process, then the MF would probably be a choice to move along more quickly. My 2 cents.
    I am actually planning to re-polish this car for spring/summer this weekend. Went straight to Coll 845 for the winter after the UC. Paint still looks great but the more refined polish should really bring out the gloss that I didn't quite get with just the UC last fall.
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
  1. Acura and Honda with Soft Paint
    By jimlenz in forum Auto Detailing 101
    Last Post: 05-03-2017, 06:50 PM
  2. Replies: 17
    Last Post: 06-08-2016, 08:23 PM
  3. Help with DA haze Soft Honda Paint
    By kris636 in forum Hot topics & Frequently Asked Questions
    Last Post: 06-07-2014, 03:18 PM
  4. US Honda Paint is soft???
    By Björns Biltvätt in forum Auto Detailing 101
    Last Post: 10-12-2012, 06:43 AM
  5. Your advice for a super soft black Honda paint
    By zckid in forum Ask your detailing questions!
    Last Post: 06-11-2011, 12:07 PM
