Re: Thumbs Down on LC HT Pads
Originally Posted by Setec Astronomy
OMG if it's one of those old red & white ones that came with the G100 they are terrible.
Nope, got rid of that one a long time ago!
Yep, read it....that's why I got the LC pads for my old machine.
The LC Hydro, Flat and CCS are all 7/8" thin while the Meguiar's W7006, W8006 and W9006 are all at just about an 1 1/4", that's about twice as thick as the LC pad. (notice the Megs MF pads are thin?)
Mike, am I missing something here?
7/8 x 2 = 1 3/4 inch which is a whole half inch bigger than 1 1/4 inch...
There are many different combinations of hook and loop (velcro). Hook and loop are matched like a nut and bolt. Some mfgrs. use an aggressive loop and some use a shorter nap length loop. This will affect on how the backing plate sticks to the pad.
Oh boy...another thing to worry about...it's not bad enough I had to add meteors to my list this week?
Hey thanks for taking the time to do the actual math. I don't do math in my head any more so I just took a quick stab at it.
The BIG picture is thicker pads don't work as well as thinner pads on da tools like the PC.
They'lll rotate under pressure till they start to get wet with product and then performance falls off...
That was the point I made here back in 2009 on this forum....
With any process using a first generation PC style polisher, as soon as you notice the pad to stop rotating under pressure, one way to restore pad rotation and oscillation is to switch to a clean, dry pad. Of course this means having more clean, dry pads on hand.
When I went to buff out a 1954 Corvette for Corvette Mike I took lots of extra polishing pads because at that time the only DA style polishers available were the first generation polishers and I knew as my pads became wet with product they would stop rotating and the job would take longer.
This car had an antique lacquer paint job on it so I didn't want to use rotary buffer but instead play it safe and use the PC.
I count 7 yellow polishing pads in the below picture, as one pad would quit rotating effectively I would swap it out to a clean, dry pad.
And this is why I normally always type each and every word so carefully with everything I write.
Thanks Roshan...
Thank you so much for chiming in Eric. I had a meeting to attend first thing this morning and after that I was going to send you the link to this thread. I'm glad you found it and chimed in already.
You know I love your products and trust they are of the very highest quality from experience. So when I see comments that don't reflect what I know from first hand experience I like to find out what's going on and make sure accurate information is being presented.
Thanks Roshan...
:lauging:
Haha ok I was just making sure we were on the same page! I do like my low profile hydrotechs more than my normal sized ones
It's more likely the backing plate that's the issue, not the pad itself. LC backing plates grab onto pads a lot more than the Megs backing plate does. I have to really work to get pads off of the LC backing plate, but the Megs they come right off. I use H20 pads and MF pads on both.
I notice the same thing. I use a 3.5 LC plate for my 4" Megs pads. I really have to use some effort to get them off.
On my Megs plates, the pads come off easy when needed. You can also tell the quality difference in a Megs plate vs an LC plate. Hence, wont be buying any more LC plates in the future.
By attention2detaillhc in forum Marine31 Boating Products
Last Post: 05-02-2018, 01:14 PM
By Ebg18t in forum Customer Comments
Last Post: 07-11-2015, 01:19 PM
By ROMEO in forum Off-Topic
Last Post: 04-30-2011, 12:04 AM
By ehuth1 in forum Auto Detailing 101
Last Post: 11-07-2007, 12:51 PM
By Kelso in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-31-2007, 11:14 AM
