CCS Foam Pad from eBay: Fake, Imitation, Counterfeit?
Hello everybody!
I just purchased a 4" foam pad that was advertised as "Lake Country 4 Inch Orange Cutting Foam Pad CCS" but through comparison to my 7" CCS orange foam pad, there are two things that are different:
1. the recess/dent holes is different. it's a ring not a dent, looks like someone put an imprint prior shipping instead of during the foam construction at the factory.
2. the color is slightly off, lighter.
Please see attachment. I stacked the 4" pad on top of the 7" pad.
Second photo is up-close of 4" pad
Re: CCS Foam Pad from eBay: Fake, Imitation, Counterfeit?
I don't know...the dent holes are pretty uniform. They may be a little different on the smaller pads...does the texture feel like the 7 inch pad?
Then there is the difference in the color too???
I didn't pay close attention to the feel of the foam.
It's actually not very uniform. Not sure if it suppose to happen but couple of the ring just turns flat when I rub it back and forth.
I want to see if any mod can chime in since they handle a lot of LC pads. I don't want to conclude anything yet.
I'm sure if a mod chimes in he/she will tell you if you want a genuine LC pad, buy it from Autogeek, not from eBay.
These are manufactured items with tolerances, etc. Perhaps a different tool is used for the smaller pads, with different dimple definition, or perhaps it was more worn, or not at the same temperature, maybe the foam was a slightly different density (within tolerance).
I have a bunch of 5.5" and 4" CCS pads. As far as I can tell from the pics they look legit to me.
They could be factory seconds.
Those look legit, with any manufacturing process there can variance in uniformity for example when you fire up a machine or process on a Monday morning after everything has been shut down all weekend...
Are these with de-lamination issues like LC pads or any better?!
Flex 3401 & PE14
I bought it for under 6 bucks per 4" pad. I'll give it a try and see if those ring will be flatten out or not but i'm afraid it's going to happen. I mean, just by rubbing it last night, the ring is getting lost.
Well, caveat emptor. You could have but them right here for "under 6 bucks per 4" pad": 4 inch CCS Spot Buffs Orange Pads 2 Pack
By wantboost in forum Auto Detailing 101
Last Post: 05-14-2017, 12:39 PM
By Billy Baldone in forum Auto Detailing 101
Last Post: 08-26-2016, 09:22 PM
By Mike Phillips in forum Off-Topic
Last Post: 06-05-2012, 07:15 AM
Last Post: 01-20-2012, 10:46 PM
By PPLd in forum Auto Detailing 101
Last Post: 02-14-2011, 10:10 AM
