As others have said, it is too much heat generated by high speed, excessive pressure, stationary movement, etc.
Here are some pics of a LC CP cutaway. You can see the bottom pad showing the compression and solidification of the foam as it fused togther. Pulled apart you can
see the top has a cavity and the adhesive failure and fretting of the foam.
Attachment 9940
