Lake Country 8.5 inch Hook & Loop DuroWool Twisted 100% Wool Aggressive Cutting Pads
Re: Lake Country 8.5 inch Hook & Loop DuroWool Twisted 100% Wool Aggressive Cutting Pads
Great information, Mike! But I would NOT use a 8,5" wool pad with the Flex rotary, it can barly handle 6.5".
Which Flex are you talking about?
There's two Flex Rotary Buffers listed above, a full size and a lightweight. I've used large pads with the lightweight and after doing so I'm limited my use of the lightweight rotary buffer to small pads and if you search my posting history you'll see that's what I recommend also.
You can however use the larger size pads with the full size Flex.
Sorry Mike, I only saw the 3403, wich is the small one
The full size Flex is a workhorse
Sorry Mike, I only saw the 3403, which is the small one
No problemo... the above thread is a little picture and content heavy... it's easy to miss something...
By Bryan@Autogeek in forum New Car Care Products
Last Post: 04-07-2017, 07:40 PM
By clanderson in forum Wool & Foam Buffing Pads
Last Post: 08-03-2014, 11:58 AM
Last Post: 04-22-2010, 08:55 AM
By Mike Phillips in forum Wool & Foam Buffing Pads
Last Post: 01-08-2010, 10:14 AM
Last Post: 11-09-2007, 10:20 PM
