Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,031
    Re: Lake Country - CCS vs CCS Cutback pads
    That should do the trick.
    I like to start with five drops around the circumference of the pad, myself - to stave off saturating the center of the pad, where all the "stuff" accumulates.
    Did it make an improvement?
    Speed 4 or 5 is fine on that tool. It's actually more powerful than the PC. I had one, and didn't ever take it past 4.
    Try it again and slow down your arm speed, maybe even lighten your pressure. You want those abrasives rolling around, chewing off the paint. Lighter pressure keeps that pad rotating over the surface. Light but firm pressure is how I describe it.
    Super Member VISITOR's Avatar
    May 2007
    9,777
    if you're using a traditional pc-style DA i would go with the lake country thinpro or GG Boss Pads as they are thinner. if i'm not mistaken the ccs pads are thicker...
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Griots polisher wobbles with Lake Country pads but not CG pads
    By SightHound01 in forum Auto Detailing 101
    Last Post: 10-28-2019, 01:15 PM
  3. Meguiars ultimate compound/polish with lake country pads or hex logic pads
    By Delicate Touch Auto in forum Products Guides
    Last Post: 08-16-2016, 08:20 PM
  4. Lake country hydro tech flat pads. Pads are ripping on my makita
    By Ncs0816 in forum Wool & Foam Buffing Pads
    Last Post: 10-04-2013, 08:38 PM
  5. CCS Smart Pads™ Dual Action 5.5 inch Foam Pads by Lake Country
    Last Post: 01-08-2008, 08:03 AM
