Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Junior Member mikejames's Avatar
    Oct 2014
    67
    Re: Lake Country CCS 6.5 pad repair ??
    I have not tried it but wonder if something like 3M Foam & Fabric 24 Spray Adhesive might work, or a similar spray adhesive.
    Super Member WAXOFF's Avatar
    Jun 2012
    Just south of the Burgh
    1,283
    Not to sound degrading to you. I was just trying to make a point that whether it was user error or a defective pad I would contact the manufacturer to see if may there was a bad run of glue on that certain pad or maybe they could give some insight. I have heard of having a pad slightly damp can cause a steaming effect when it gets hot and starts to degrade the adhesive also. My only point was don't try to use something that could compromise your work and cause some worse to happen. It's kind of like buffing out a deep scratch and I'm sure we have all done it before. you thing just a little more and then the clear is gone in a instant.
    2011 Compass Latitude Bright Silver/ 2017 Nissan Rogue SV AWD Premium Glacier White
    REFLECTIVE IMAGE DETAILING
  3. #13
    Dec 2014
    Boonsboro, Md
    2,724
    There is a thread somewhere around here about some of the LC (flat pads I think) pads delaminating and that was probably just a bad run of them.
    I should have mentioned that mine are mostly from user error. Too much polish/compound, too much pressure, moving the polish to slowly or dwelling in one spot, and/or to high of speed(Duetto).
    Here are the worst ones.
    Lake Country CCS 6.5 pad repair ??-img_2362-jpg
    One definitely over heated/saturated. The one half folded back is too, just not as bad. It's sunken on the face in the center. One "like new" just with the loop side cleanly gone. The other on is in decent shape, just a little coming loose around the edges.
    ____________
  4. #14
    Super Member Jim w's Avatar
    Dec 2015
    South Jersey
    310
    Has anyone tryed contact cement or rubber cement?
    Spread a little on each surface, let dry till tacky and then
    join each side together. I would think that would work,
    however I have no experience with gluing pads.
    Jim
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Lake Country, what did you do?
    By parttimer in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 11:22 AM
  3. Which Lake Country Pad?
    By SonataLF in forum Auto Detailing 101
    Last Post: 02-21-2016, 06:34 PM
  4. Which Lake Country Pad?
    By mdgrwl in forum Auto Detailing 101
    Last Post: 02-24-2014, 10:22 AM
