Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Sep 2015
    Conway, MA
    44
    Fuzion by Machine?
    I'm a newbie and I was wondering if you can apply Wolfgang Fuzion with DA polisher? I love the product, but just got a GG 6" DA polisher and thought I could only use a liquid polish.
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Re: Fuzion by Machine?
    Yes you can.
    Here's an article written by Mike Phillips:
    How-to Machine Apply Wax using a DA Polisher
    May 2008
    4,108
    Here's another article Mike wrote and within that article, you can find a section about how to apply paste waxes by machine:
    http://www.autogeekonline.net/forum/...ge-paints.html
    How to apply a paste wax by machine
    You'll need a DA Polisher like this Porter Cable 7424XP with a 5.5" Flat Gray Finishing Pad, Dodo Juice Banana Armour Hard Wax and some Microfiber Gloves. For this step you could substitute any quality finishing wax or paint sealant. Here's a list of finishing waxes, sealants and hybrids.
    How To Choose The Right Wax or Paint Sealant for your Detailing Project
    For this procedure I'm going to place a microfiber glove over one hand in order to hold the wax without contaminating it or without it slipping out of my hand.
    To get the wax out of the plastic jar you just have to carefully knock it out using inertia by holding the jar upside down and then knocking it against your other hand with a Microfiber Glove on it.
    Then hold the polisher in one hand and the wax in your other hand with the glove on it and blip the on/off button of the polisher while holding the wax against the face of the pad and you can quickly transfer wax to the pad.
    The Microfiber Gloves keep the wax clean until you place it back into the jar and enable you to grip the wax so it doesn't slip out of your hand and onto the floor...
    Ready to start laying down some Banana Armour...
    It takes a little muscle to do this because in one hand you're holding the wax and the other hand is holding the polisher for the duration of time it takes to run the polisher over every square inch of the car. If you had a helper they could hold the wax with microfiber gloves on and you could use both hands to hold the polisher, then as you needed more wax your helper could apply the wax while you hold the polisher, otherwise hit the gym.
    If you look carefully you can see I spelled out Dodo on the hood in my wax pattern...
    In the forum world you'll often read people talking about getting the "Sun Shot" , that's where they pull their project car out into the sun to show there are no swirls in the paint.
    The below shot is kind of like the "Sun Shot", but I call it the "Fun Shot" because I was just having some fun with the Dodo name in wax.
    I used a rubberband to hold a Cobra Indigo Microfiber Bonnet over a 3" Griot's Garage Polishing Pad on a DA Polisher and took the wax off only where the word DODO was spelled out and then pulled the car into the sun for a "Fun Shot".
    The Sun Shot Fun Shot
    Yep, this is how you get the high overhead shot, you have to get up in the air a little ways...
    Removing the wax
    After capturing the fun shot I pulled the car back into our studio and let the hood cool down and then removed the wax by hand using Cobra Indigo Microfiber Towels. Always fold your towels 4 ways to give you 8 sides to wipe with and to provide cushion to spread out the pressure of you hand.
    Below is a link to a video and at the end of the video I show how to remove Wolfgang Deep Gloss Paint Sealant 3.0 by hand using the Cobra Indigo Microfiber Towels. In this video I share a technique I call "Breaking the Wax Open" and then "Creeping Out". Wolfgang Deep Gloss Paint Sealant 3.0 is a finishing synthetic paint sealant but the technique shared in the video can be used with any finishing wax, sealant or hybrid.
    How to Apply a Synthetic Paint Sealant by Hand using the Straightline Technique
    After removing the majority of the wax it's time to give the paint a final wipe. Here's an article on the technique for giving paint a final wipe.
    The Final Wipe – Tips for creating a streak-free, show car finish
    Sep 2015
    Conway, MA
    44
    Quote Originally Posted by Marc08EX View Post
    Yes you can.
    Thank you so much. I just went through the article and it makes sense. I can't wait to try it with the Fuzion. I have already had more people comment on my car after claying/Fuzion. With the GG polisher, I wanted to try some additional correction and then wax. However, I was thinking that I'd have to compromise the Fuzion. THANKS AGAIN!
    Apr 2012
    7,494
    I apply all my LSP's by machine, including Fuzion, Celeste D by CG, Souveran, Midnight Sun. I use my 3" Rupes with a 4" Blue LC pad. I'd suggest getting the 3.5" LC BP to use on your GG6. I have this set up too. For a twist, instead of knocking out the wax from the jar (cuz it can break apart or fall on the ground) I use a small rounded butter knife and spread it across the pad. I specifically started suing Fuzion this way. It makes it really easy to control how much you use. I can do a whole vehicle with about a teaspoon this way.
    2019 Nissan Rogue SL
    Super Member Jaretr1's Avatar
    Jan 2011
    Miami
    2,391
    The neat thing about using the machine is it really does allow you to spread the product evenly and thinly. A very thin coat of Fuzion is all thats needed. If you are getting ANY product on the paint, you are getting enough.
    However, with a wax as easy as Fuzion, I am not sure it saves any time though.
    Jul 2013
    Apex, NC
    1,283
    I use the short side of an old credit card to scrape out a small amount of wax then use the card to spread it across the surface of the pad like a butter knife.
    Super Member parttimer's Avatar
    Aug 2013
    1,564
    I flip the jar over on the lid so the puck comes out on the lid, then rub the pad over it. I use a red pad on a DA.
    At my 3-day classes, we apply everything by machine except for coatings.
    If you read through this most recent thread you'll see multiple cas machine waxed....
    Pictures & Comments: July 2015 Detailing Boot Camp Class!
    Including applying Fuzion to this Chevy SSR we de-swirled.
  10. #10
    If you want to do it the most econical way then use a Griot's Garage 3" Mini Polisher with a 4" Rupes white foam pad like I show here.
    1966 Blown Nova - Extreme Makeover - Pictures & Videos
    Machine Waxing
    Next step... seal the paint with Pinnacle Black Label Synergy
    Most people hand apply their waxes but I'm a machine guy. By this I mean I try to do EVERY step by machine and the reason why is because the human hand cannot compete with a machine when it comes to creating the best results. Period.
    First a quick lesson on how to machine apply a wax using the Griot's Garage 3" Mini Polisher with Rupes 4" white foam finishing pads....
    Here's the owner machine applying Synergy....
    Here's Denis machine applying Synergy while his brother Matt watches.... these two brothers flew to Stuart, Florida from New York just to be a part of this project.
    Dry to a haze
    These next pictures show a thin machine applied coat of Synergy drying. This wax needs to dry to a haze before removing.
    Same techniques work on any car, truck or SUV I just tend to get these old cars down to the show car garage.
    You can either place the face of the pad into the wax jar and blip the on/off switch or use the blade of a PC wrench or a butter knife or ? to spread some wax onto the face of the pad.
    I show this in my how-to book, The Complete Guide to a Show Car Shine. See my Signature Line.
  1. Fuzion Paste by Machine.
    By jankerson in forum Wolfgang Car Care
    Last Post: 12-07-2020, 04:52 PM
  2. 1966 Corvette Stingray - Machine Polish & Machine Wax
    By Mike Phillips in forum Show N' Shine
    Last Post: 05-04-2016, 07:27 AM
  3. Fuzion Friday! Full Size Fuzion Only $100!
    By Nick McKees37 in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 03-03-2016, 12:19 AM
  4. machine application of fuzion
    By bk2nrml in forum Auto Detailing 101
    Last Post: 11-12-2011, 04:11 PM
  5. Are Fuzion/476 or Fuzion/Opti-Seal Possible Combos?
    By islandvic in forum Auto Detailing 101
    Last Post: 10-04-2008, 07:55 AM
