TSR dusting?
I thought the TSR was not supposed to dust? I've been working on my car in the garage, probably about 85F ambient or so, and I've ended up having to mist the pad with water first each time (heard about doing that around here somewhere) otherwise it starts dusting and clumps of it stick to the paint. Am I doing something wrong? Using a PC 7424 on 5000 opm with a white 5 1/2" CCS pad. After about 3 section passes it would start dusting like crazy. I primed the pad and then was using the 3 drop method after that.
Re: TSR dusting?
Sounds like you are using too much product. Make sure you are also keeping the pad clean between sections!
Re: TSR dusting?
thick CCS pads and DAT polishes are not a good mix imo...
I told my wife that a husband is like a fine wine; he gets better with age. The next day, she locked me in the cellar.
~Tim
Re: TSR dusting?
Don't think so, put an X on and spread it to prime the pad, then 3 small dots. It seems to be doing better since I started using the water so I think maybe the heat was causing an issue. It's like it was gumming up and balling up due to drying out before it got a chance to work.
??? The 5 1/2" x 7/8" low profile CCS? I have no problem getting different pads, I'm just not sure what to get now as I wasn't aware there was anything lower profile in any of the lines.
Re: TSR dusting?
I like the TSR, it's my goto polish. It will dust some when it's hot, but pretty much anything will in dry hot air. I use the LC Hydro Tech pads and they do work quite a bit better than Flat or CCS pads IMO. I don't use water but some ONR Mixed like clay lube to "lightly" mist the pads when I get a little dusting that help but you still will get some.
"Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration." Lincoln's First Annual Message to Congress, December 3, 1861.
Newport, Oregon USA!
Re: TSR dusting?
Sounds about the same amount I use. Maybe just try to work a bit smaller area and make sure the pad is always clean. Hot dry days will also lower any polish's work time.
Re: TSR dusting?
Thanks all, I was trying to keep the areas small, guess not small enough. Hmm now I wonder if I was working it too long (is that possible on a DAT?). I was doing 6 section passes on each section.
Lol @ the clay lube, I had a big bottle of that already mixed up. I thought maybe it would interfere so I just used water.
Re: TSR dusting?
I would also suggest using less polish as well. When I get dust, it is almost always too much product in the pad (either over primed or dried out). This can be over buffing as well which is the dried polish problem.
For me, I find that the x method can leads to over priming. I would start with 2x the amount on the first panel and then switch to the per panel amount for Menzerna polishes. You just need enough to cover the work panel and you adjust based upon the pad as well since some pads absorb or behave differently. I would also clean the pad after every panel.
By aliitp in forum Auto Detailing 101
Last Post: 08-22-2016, 05:50 AM
By CanuckCleaner in forum Auto Detailing 101
Last Post: 04-05-2015, 09:34 PM
By Setec Astronomy in forum Off-Topic
Last Post: 09-09-2011, 10:39 AM
By Infinite1 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 08-14-2007, 04:38 PM
By joshrog in forum Auto Detailing 101
Last Post: 05-02-2007, 12:37 PM
