Re: "con"-fuzion - wolfgang Fuzion application and removal
IMHO, yes wait 12-24 hours before using a QD.
IMHO: If you are leaving a product on to cure that says to WOWO you are essentially taking longer for it to cure to the paint. The products need oxygen to cure; hence why they are liquid/pliable when in their containers. When you leave a wax on to cure instead of WOWO you are allowing the outermost layer to cure before the product that is actually most in contact with the paint. Then you wipe off the product that has had some time to cure, and now the product that is still attached to the paint surface(not itself) is starting to cure from oxygen exposure. No, a product that needs hours to cure is not going to feel its slickest as soon as you wipe it off the paint. It has to cure and harden to get that slick property. Hope that makes sense. It just does to me. And yeah, your going to be lengthening the curing time and lessening the efficiency of the product if you applying any moisture to it right after it is applied. However, they do say that spritzing the surface after applying carnauba wax helps it cure to the paint. But, I think it still needs to set for at least a couple hours before doing so. If you are using anything with sealants/polymers in it you need to give it the whole curing time(8-12-24 hours) before topping/layering. Just my experience and knowledge.
Originally Posted by mg6045
I have been playing around a little bit with the wolfgang Fuzion wax.
Yup, love Fuzion. Ready like how it beads:
I also found a slight "improvement" when removing the wax with a machine/mf bonnet (I use a Flex DA). See this thread:
Fuzion Water Beads
Regards,
GEWB
Linux Reg. User #206357 (Feb. '99)
"Can't get there from here."
Originally Posted by Dr Oldz
The difference you are feeling is the polymers bonding to the surface of your paint. It takes most sealants 12 hours to fully bond to the paint after being buffed off! Most sealants feel slicker after the 12 hour curing time in my opinion! This bonding time is why they tell you not to get the vehicle wet or layer on top of the sealant till the product is fully cured!
Some good information here!
Many overlook this waiting or curing time but it is an important step for products to bond and cure thoroughly before recoating...
Always set yourself up for success......
AS much as we pay for the Fuzion I want to make sure I do things right.
As always I learn alot on this forum.
THANKS !!!!!
Fuzion Water Beads
Regards,
GEWB
THAT is a sick picture!
I've seen a lot of water beading pictures in my life but I've never seen a picture as cool as this one...
Kind of reminds me of the old rance dance cans/commericals when I saw that picture.
Tom
THANKS !!!!!
Actually, the price PER APPLICATION isn't too bad, only the up front cost.
Apply Fuzion as thin as you can (but still get complete coverage). Once you have that down pat, you should get more than 30 applications from a regular size jar - that's less than $3 an application.
Regards,
GEWB
Hello Mike -
Thanks for the kind words.
Note that I didn't intend to hijack this thread!
Regards,
GEWB
By engineerwolf in forum Ask your detailing questions!
Last Post: 03-27-2018, 08:07 PM
By hoyt66 in forum Auto Detailing 101
Last Post: 08-23-2015, 01:45 PM
By Klasse Act in forum Product Reviews
Last Post: 12-05-2012, 08:03 PM
By IID in forum New Car Care Products
Last Post: 10-08-2012, 12:59 PM
By Iczy in forum Wolfgang Car Care
Last Post: 06-03-2010, 04:52 AM
