So if it DOES get wet before setting....
Well that low probability of a bit of rain late in the evening turned into a little shower early in the afternoon, about 4 hours after a second coat of Wolfgang sealant was applied.
Is it a done deal that this goofed it up? What symptom am I going to be watching for and what remediation is possible?
Re: So if it DOES get wet before setting....
It wont be totally a waste. It just wont have the full durability as if it had fully cured and the look might lose a fraction.
When was the first coat of WG applied. Since you should have full protection from the first coat.
Ed
Moderator/Consultant for Autogeek.net
To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
While my approach takes more time, the results are far superior.
SELF BANNED
It will loose durability and you will see little faint water spot all over the car.
Yesterday morning, so it was on for about 24 hours before the second was applied.
You will have the full protection from the first coat. Second coat that would have gave more shine, slickness and protection. Will be compromised a little, I wouldn't worry too much. Sucks that your plan didn't work out, with the second coat..
Ed
I'm laughing really - living in a semi-arid part of the country and I see the forecast and think nah, it won't materialize, and even if it does it's more than 12 hours out... and it's not just a little rain that showed up early, it's a good soaker!
I just get too excited and impatient sometimes with new stuff. Glad to hear it's not going to slough off and mess up my trim or something like that. I can live with a do over and actually have fun with it. This stuff is so easy to work with. Sure looked good this morning, too!
So if I want to get what I was going for, I need to clean this off and start with another sealant base application, is that right? Or can I lay another layer right on top of the one that got damp?
You can always go over it with a QD and restore some of the sealant's protection. It would also rejuvenate your "just waxed" look!
By masterdetail in forum Auto Detailing 101
Last Post: 01-27-2012, 12:18 AM
By Jimmie in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 06-18-2011, 09:49 PM
By scooterguitar in forum Auto Detailing 101
Last Post: 06-11-2008, 05:45 PM
By trhland in forum Auto Detailing 101
Last Post: 04-12-2007, 07:33 PM
By Mike T in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 06-15-2006, 06:47 PM
