Wolfgang Deep Gloss Spritz Sealant
Im confused slightly...
the product description reads that you should apply the sealant spritz and then fuzion, but later, it mentions using the spritz over fuzion as a qd instead... i know it can be used both ways, but the thought of a sealant over fuzion has me flustered a bit...
This spray-on sealant is a revolution in paint protection! Wolfgang Deep Gloss Spritz Sealant is a direct descendant of our ground-breaking wipe-on sealant, Wolfgang Deep Gloss Paint Sealant. The two share virtually the same blueprint, with one exception. Deep Gloss Spritz Sealant has engineered liquefied polymers that disperse easily through the spray nozzle and then cross-link on the paint surface to form one solid polymer coat over the paint finish.
If you really want to kick up the shine on your paint, apply a layer of Wolfgang Füzion Wax over Wolfgang Deep Gloss Spritz Sealant after the sealant has cured. You’ll get the long-lasting protection of the sealant and the warm glow of carnauba.
then this:
Wolfgang Deep Gloss Spritz Sealant maintains the gloss and protection of Wolfgang Füzion Wax.
Re: Wolfgang Deep Gloss Spritz Sealant
I was a little confused when I read it also. It is a sealant, so you would put it down first then top it with a carnuba. Fuzion is a carnuba/sealant combo. It has the same polymers as the DGPS sealant. So it would maintain the fuzion when used as a QD.
I too would use Fuzion over the spray sealant, Wolfgang does make a spray that can be used over Fuzion as wanted but I find Souveran Spray Wax works equally well too.
OK, i think i might try the spray sealant... what, in terms of durability, does it add to the fuzion?
as with most/all spray sealants its rather limited against the liquid counterparts. I dont know if the included water/lubricants seem to cut down on the durability a bit.
i can only assume they will, but i was just curious if anyone had an idea or if they have noticed from experience...
sadly enough, the way the fuzion looks on test panels, i will reapply it every few weeks just to have the "just waxed look"...
I have found that all high end waxes usually need reapplication after 3-4 weeks for that look. I do find using the same manufacturers soap and qder can help. I would also highly suggest trying Souveran Spray Wax over any older carnauba wax as it just seems to add something and bring the look back alive.
I use WGSS and UPP's Spray Wax over Fuzion and IMO they work fine to help maintain the shine.
What is the differenc between the Wolfgang Deep Glass Spritz vs. Instant Detail Spritz?
The deep gloss spritz is a sealant(deep gloss spritz sealant). The instant detail spritz is wolfgangs quick detailer.
By Mantilgh in forum Wolfgang Car Care
Last Post: 03-21-2016, 08:32 PM
By RayBay30 in forum Wolfgang Car Care
Last Post: 02-01-2014, 09:06 PM
By lkotsios in forum Auto Detailing 101
Last Post: 04-03-2013, 05:52 PM
By bimmer75 in forum Auto Detailing 101
Last Post: 10-30-2008, 08:53 AM
By makdaddy626 in forum Auto Detailing 101
Last Post: 04-12-2008, 10:07 PM
