Results 1 to 6 of 6
    Dec 2016
    69
    Liquid Seal Durability?
    Wolfgang Convert. Dumping - trashing my entire cabinet of X-brand products and replacing with Wolfgang equivalent.
    Absolutely love the Liquid Seal product. So easy to apply and such sharp, clear reflections. Considering properly corrected paint and wiped down with a pre-wax cleanser or IPA, and then a coat of Liquid Seal directly on the squeaky clean corrected paint, how durable is the Liquid Seal? Is it feasible to use Liquid Seal instead of 3.0 Sealant? Can you 'layer' Liquid Seal with sufficient time between coats to extend durability?
    Thank You.
    Dec 2016
    69
    Re: Liquid Seal Durability?
    Well, with 116 views and no replies, I figured it was time for a test. I completed a 2-stage correction using Wolfgang Swirl Remover (Wolfgang Uber Compound on the troublesome spots) followed by Wolfgang Finishing Glaze on the entire car. I then did a thorough wipe down with Menzerna Top Inspection. I then laid a generous coat of Wolfgang Liquid Seal on the entire car and waited a couple hours before leveling the high spots with a Wolfgang MF towel. I will let this coat cure for 24 hours and lay another coat of the Liquid Seal down. Then we'll see how long it lasts...
    Liquid Seal Durability?-img_0485-jpgLiquid Seal Durability?-img_0121-jpgLiquid Seal Durability?-img_0122-jpgLiquid Seal Durability?-img_0488-jpgLiquid Seal Durability?-img_0490-jpg
    Dec 2016
    69
    PS - Wolfgang Uber Compound and Swirl Remover 3.0 work incredibly well but are SUPER 'dusty.' I used a Lake County Orange pad with the Uber Compound and the Lake County Pink pad with the Swirl Remover. I used Rupes Yellow pads with the Finishing Glaze which was zero-dusting.
    Super Member Loach's Avatar
    May 2014
    Chicago
    452
    WGDGPS 3.0 will be much more durable than Liquid Seal. I wouldn't use Liquid Seal solo on the paint, it's a great topper for DGPS and a wide variety of other sealants though.
    That 3-4 week period I really noticed Liquid Seal diminish compared to DGPS, Crystal Seal had the same performance. Still some of my favorite products.
    Dec 2016
    69
    The GTS is sort of a garage queen, so probably not the best vehicle to test 'durability.' I typically use Wolfgang rinseless wash which is pretty mild. I also use the WG Spray Sealant as a detailer because it seams to feel slicker under the towel and flash cleaner and clearer than the WG spritz detailer. So maybe for this type of car, the Liquid Seal will provide decent protection. To my eye, it just has ever so slightly sharper clarity and reflections on black paint than the DGPS 3.0.
    Super Member 01GreyStangGT's Avatar
    Aug 2009
    Springboro, OH
    857
    I too use the Liquid Seal to top the WGDGS.
    2014 Ford Mustang GT Track Pack-Black
    2015 Chevrolet Silverado Crew Cab 4x4- Summit White
  1. Durability Test : Meguairs ultimate liquid wax
    By alfierenadhie in forum Product Reviews
    Last Post: 01-28-2019, 11:09 AM
  2. Replies: 13
    Last Post: 07-17-2016, 09:36 AM
  3. Replies: 2
    Last Post: 07-24-2014, 09:20 PM
  4. Opti Seal / Crystal Seal / Deep Gloss Liquid Seal
    Last Post: 02-22-2013, 07:03 AM
  5. Opti-Seal durability
    By pcw25 in forum Auto Detailing 101
    Last Post: 02-22-2012, 09:31 PM
