Results 1 to 6 of 6
    Regular Member Paulyfe12's Avatar
    Apr 2014
    149
    Cool compounds or polish question
    im gonna be fixing up some scratches that require a wetsanding job. so I wanna know what compounds and polishes could I use by hand to remove 2000 to 3000 grit wet sanding marks.
    Super Member TuxedoTaurus's Avatar
    May 2014
    Tenessee
    554
    M105 and M205 can be hand applied
    Sent from my GT-P5110 using AG Online
    Detailing is a way of life, not a hobby!
    Apr 2014
    149
    Re: compounds or polish question
    tru but wouldn't m105 be a little over kill?
    Apr 2014
    I've found Menzerna Fast Gloss 400 Compound (FG400) to work better for me than Meg's 105 which I also have and used.
    Menzerna Fast Gloss Compound, Fast Gloss 400, FG400 compound
    From Auto Geek site:
    "Cuts like a compound – finishes like a polish!
    Menzerna Fast Gloss 400 Compound (FG400) is the long anticipated new compound from Menzerna Polishing Compounds that was designed to deliver the fast cutting action of a compound with the finish and workability of a polish. Menzerna Fast Gloss 400 Compound will quickly become an asset to the professional reconditioning industry with its ability to effortlessly remove 1200 grit sanding marks, heavy scratches, swirls and oxidation on all paint systems while leaving a high gloss finish that is not typically expected from a compound."
    Apr 2014
    149
    Do you know if the Menzerna Fast Gloss can be applied by hand? or wil it only really work with a DA?
    May 2014
    Tenessee
    554
    Maybe and maybe not. Over a larger area it won't be as aggressive, but in an isolated area you can cut pretty hard. I recommended both because you asked for compound and polish. I would test the area first with 205.
  1. Question on compounds acting as a filler and question on YouTube video.
    By MartyK in forum Ask your detailing questions!
    Last Post: 06-10-2020, 08:57 AM
  2. Polish compounds?
    By Indiglofish61 in forum Auto Detailing 101
    Last Post: 09-13-2018, 09:27 PM
  3. Swirl remover/ polish compounds
    By aztec1987 in forum Products Guides
    Last Post: 05-24-2017, 09:35 PM
  4. Compounds, polish, glaze
    By akj in forum Auto Detailing 101
    Last Post: 02-28-2013, 06:00 AM
  5. What Compounds, Polish Etc?
    By payj in forum Auto Detailing 101
    Last Post: 08-20-2011, 11:19 AM
