Dislikes:
Re: ceriglass? tool?
Yes i will be using ceriglass to repair the scratches in the windows as well as the 5" carpro rayon glass polishing pads.. and i will see how it turns out with you before i try. and speeds are l and h. thats it. and yes it looks like a pistol...
heres a picture of the tool.
Stock # AT402MCA
Name Sander, Dual Action, Micro, 3"
Price** $208.35
Brand Blue Point
Country Of Origin Japan
Description Micro Composite Sander
Air Consumption, Average, CFM (SCFM) [L/MIN] 2.07 (14.7) [58.62]
Air Consumption, Free Speed, CFM (SCFM) [L/MIN] 2.1 (15) [59]
Air Inlet Thread Size 1/4"-18 NPT
Pad/Disc Size, Dia., inches (mm) 3 (76)
Free Speed, RPM 15,000
Horsepower, HP 0.25
Length, inches (mm) 5.2 (133)
Rated Power, hp (kW) 0.25 (.19)
Recommended Air Pressure, psig (kPa) 90 (620)
Recommended Hose Size, inches (mm) 3/8 (10)
Sound Level dBa Pressure 84
Sound Power Level, dBa 96.9
Sound Pressure Level, dBa 84.2
Spindle Thread, inches 5/16-24 UNF
Vibration Level, m/s² <2.5
Weight, lbs. (kg) 1.1 (.50)
OK, yes it will work. How quickly I'm not sure. I just ordered the 3" carpro pads. The 5" pads wont work on your 3" backing plate.
Sent from my SAMSUNG-SGH-I777 using AG Online
okay. is there anyway to remove the backing plate and stick a five on it? or cant i cut the pads down to fit the 3 inch?
I'm not sure if a five inch plate with work on that tool. I'm don't think it would spin the pad under a load.
You can cut the pad to fit, but it would be a waste.
I'm guessing the 3" pads I ordered should be here Friday or Saturday this week.
alright. ill just wait until you test yours out..
15,000 RPM? Yikes! You have to keep Cerri Glass wet and it flings everywhere with a DA. I couldn't imagine 15,000 RPM. I think you'll find some on the ceiling and in your hair. Please keep us posted.
15,000 is the no load speed. But it is going to make a mess!
Originally Posted by
ken tuep
15,000 is the no load speed . But it is going to make a mess!
chrisnkaitlin
Name Sander, Dual Action , Micro, 3"
Isn't it rather odd that this particular DA Sander has been given RPM ratings?
NOTE: I can think of at least one other manufacturer of DA's to do likewise.
And: There really isn't an truly accurate chart to convert between RPM's and OPM's, is there?
However:
Flex Tools, due to their having a forced rotation DA, has come up with:
a standard ...for converting (as close as possible) their RPM/OPM ratings.
TO WIT:
Flex XC 3401 VRG ...No load speeds: 3200-9600 OPMs/160-480 RPMs
Dial #'s........OPM's/RPM's (no load).....{~20:1}
1................3,200/160
2................4,500/200
3................5,800/270
4................7,000/330
5................8,300/400
6................9,600/480
BTW:
-FLEX PE14-2-150 Rotary Polisher...No load speed: 600-2100 RPM
-PC7424XP "no load speed" 2500-6800 OPM
Now converting the OP's Blue Point DA Sander's (AT402MCA)
15,000 RPM's to ~ OPM's:
swanicyouth
15,000 RPM? Yikes!
By nine in forum Auto Detailing 101
Last Post: 08-06-2017, 02:27 AM
By rbss in forum Auto Detailing 101
Last Post: 05-25-2014, 06:09 PM
By mankool in forum Auto Detailing 101
Last Post: 05-08-2014, 12:30 PM
By alko in forum Auto Detailing 101
Last Post: 12-07-2011, 11:48 PM
By Rsurfer in forum New Car Care Products
Last Post: 12-04-2011, 03:25 AM
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
S
M
T
W
T
F
S
1 2 3 4
