I agree with swan, if you try a small spot first with your blue point tool and you're satisfied, then roll with it. But doing a entire window with a 3" pad would take days!
I own a Griots 6" , and my dad has the harbor freight version, and they both performed pretty equally when we used them side by side.
Sent from my SAMSUNG-SGH-I777 using AG Online
Re: ceriglass? tool?
Originally Posted by ken tuep
Hey Bob, the tool in question is actually a da sander, made for nib sanding dirt spots.
It has a very small orbit, making it really nice for finish sanding.
I would say its similar to the small rupes, but with a smaller stroke/ orbit.
Hey Ken I have several Snap-On air sanders/die grinders.
They have no load speeds well into the: "being a rotary" territory.
Something that may be contributable to having a such a smaller stroke/orbit.
BTW:
What glass sanding disks do you recommend for this tool?
Is there a need for an interface pad?
Thanks a ton guys! I have searched ceriglass results/reviews all over the web. Love the results of it.. I did notice many used the Griot's 6" and thought about giving it a try. Looked to do very well to me.. I am going to try this handheld tool I have mentioned just to see if it works on some glass but not my car glass first.. If so Ill give it a round and ave a few bucks but it doesn't seem at to bad of a price...
BTW:
Hey Bob, this isn't a rotary tool, it is a dual action sander/ polisher. I wouldn't recommend using a die grinder type tool for sanding, unless you're planning to repaint! Haha
I have used 3000 grit paper on glass to clean them with no scratching on a 6" air powered da sander. I used very soapy water as my lubricant.
I've never used this tool on glass, but I've used a 3m headlight repair kit, and the papers on it before. I've also used 1500-3000 for removal of dust nibs. It works pretty well on headlights, for the sanding steps. I personally like my Makita rotary with 3" pads for polishing them back up.
I have always used an interface pad when sanding with the lower grit paper. The 3m 3000 grit I have used without an interface, only because its sponge like.
I think the no load speeds wouldn't be much different than using a PC polisher. They will spin very fast with no load also, and could create damage if allowed to spin up before touching a painted or glass surface.
I'm not sure if I answered the questions you asked, but I tried! Haha.
I also have an air regulator mounted to most of my small air Sanders and grinders to be able to dial them down where they are comfortable to use. 22,000 rpm is overkill for most everything except very quick metal removal, like grinding a weld.
With you stating that you've never used the tool in question to sand glass...
My question is: Why on Earth would you ever recommend the OP to do so?
I still stand firm on my previous statements regarding this tool,
including that I'd never use this tool on auto glass.
I'm under the assumption that he is using ceriglass, and a glass polishing pad. Not sandpaper.
I did recommend he try a small spot first, before doing the whole glass.
I might run out to the garage and pull the truck in to try this out, and give a more definitive answer.
Chris, wait till I come back with a definite answer as to whether this tool will work.
Are you planning to sand, or just use ceriglass, and a polishing pad?
Chris, yours is a pistol grip type machine right? Mine is a palm type, but the specs are the same as far as free speed, and orbit size. The ergonomics are different, but serve the same purpose. Mine has a built in speed regulator, I'm not sure if yours does.
I have ceriglass, but no glass polishing pads for a 3" tool. I'm going to order some 3" pads if they sell them, and report my findings.
I'll wait till you chime in with what pads you will be using, then pick some up.
I'm certain this tool will work, but would like to document my process for you and anyone else interested.
I also never recommended he use it to sand the glass. But I will stand firm behind using it to polish the glass.
I stated I have used a 6" to CLEAN, ( usually overspray) from glass. I should have been more specific with my intentions, when I made that statement.
I appreciate you bringing all this to my attention. I speak only from direct, hands on experience.
I also assumed that because he owns a told of such caliber, that he has used it before for the intended purpose. Which is sanding and polishing in a bodyshop/ detail shop environment.
I'm taking his question, as to whether the tool will work with ceriglass to polish the scratches out. To that I say yes all day, everyday.
I do respect your opinion, and our right to disagree. No hard feelings though.
By nine in forum Auto Detailing 101
Last Post: 08-06-2017, 02:27 AM
By rbss in forum Auto Detailing 101
Last Post: 05-25-2014, 06:09 PM
By mankool in forum Auto Detailing 101
Last Post: 05-08-2014, 12:30 PM
By alko in forum Auto Detailing 101
Last Post: 12-07-2011, 11:48 PM
By Rsurfer in forum New Car Care Products
Last Post: 12-04-2011, 03:25 AM
