Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
    Nov 2013
    63
    Menzerna SF4000 or Megs M205
    Hi,
    I'm looking at Menzerna SF4000 or Megs M205 as a polish to remove some light swirls and water spots using a PC. How do these two polishes compare in terms of ease of use, correcting ability and gloss?
    Thanks!
    Feb 2011
    Minot, ND
    12,365
    Re: Menzerna SF4000 or Megs M205
    Welcome to AGO.
    What vehicle and what color?
    Nov 2013
    63
    Quote Originally Posted by smack View Post
    Welcome to AGO.
    C6 corvette in Atomic Orange.
    Super Member jankerson's Avatar
    Oct 2013
    Raleigh, NC
    1,084
    Quote Originally Posted by Tresca View Post
    Hi,
    Thanks!
    They should be about the same finish quality wise.
    M205 should have more correcting ability if needed with the SMAT technology using a more aggressive pad if needed and it's very easy to work with and remove. Buffing times are pretty long as it doesn't flash very easy.
    Both should give that great wet look after polishing though.
    I would say try both as you really can't lose either way.
    Super Member CM8 6MT's Avatar
    Nov 2012
    Fort Carson, CO
    1,840
    Quote Originally Posted by jankerson View Post
    I agree
    Nov 2013
    63
    How difficult is the Menzerna to remove? I had some Final Polish many years ago, and it was very unforgiving as to the window to stop working. Just a moment too soon and it was a sticky mess, and a moment too long and it was like cement.
    Nov 2012
    Fort Carson, CO
    1,840
    Make sure you prime well and apply thin. With a DAT product like Menzerna, its essential to break it down properly before buffing off. SMAT products like Meguiars require 2-3 passes and your done. Both work very well if used correctly.
    In time out
    Nov 2012
    South of Atlanta
    3,937
    Quote Originally Posted by CM8 6MT View Post
    THIS!
    The C6 has what you'd normally call 'hard' paint. That means 205 will likely finish down better than say if it were Toyota 'soft' black.
    Working with 205 you do 3 maybe 4 section passes and wipe the product off BEFORE it dries. If you need more 'finishing' you reload the pad with 2~3 dime sized drops and do it again, 3 no more than 4 more passes.
    Working with Menzerna you'd do 4 or so section passes with a machine speed of say 4.5 or so (on the PC machine) with medium arm pressure. Then a VERY light spritz, more like a fine fine mist with distilled water on the pad (or panel, just don't get it too wet), turn the speed up to 5.5-ish and lower your arm pressure then do a couple more section passes. Watching for the product to work down to almost nothing and it'll wipe away really easily.
    Too much product and it'll gum up, too little and you'll dry buff. Especially with SMAT products like 205. FWIW, I'd do it with 205 because it'll do it faster and easier. Now if you want to jewel it down even more afterwards, Menzerna.
    Nov 2013
    63
    Quote Originally Posted by cardaddy View Post
    THIS!
    Are these two products roughly equivalent in correcting level?
  10. #10
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    M205 has a slight bit more cut according to the polish comparison chart
    UPDATED: Autopia Car Care Polish Comparison Chart - Autopia Forums - Auto Detailing & Car Care Discussion Forum
    Retired Professional Detailer
  1. M205 or sf4000
    By Zubair in forum Auto Detailing 101
    Last Post: 11-02-2015, 04:10 PM
  2. Menzerna SF4000 Questions
    By Gokite in forum Auto Detailing 101
    Last Post: 05-30-2014, 09:40 AM
  3. Will M205 or SF4000 Remove CQuartz?
    By theblob640 in forum Auto Detailing 101
    Last Post: 05-09-2014, 09:26 AM
  4. Menzerna SF4000
    By Tresca in forum Products Guides
    Last Post: 11-21-2013, 12:04 AM
  5. Menzerna Powerfinish, or Megs M205?
    By nrengle in forum Auto Detailing 101
    Last Post: 02-08-2009, 01:36 PM
