Results 1 to 6 of 6
    Super Member parttimer's Avatar
    Aug 2013
    1,564
    The first of two scratches I would like to fix
    I bought my new RAM back in March so it saddened me when I did this. I had a metal pole with no end cap swing around and ding my front fender. I have tried Wolfgang swirl remover 2.0 on an orange pad but no joy. It does catch on your nail so I'm worried I am in a mess. I have sand paper up to 3000 grit. The second scratch i don't have a picture of yet, its on the trunk of my car. However I have tried swirl remover on a pink pad with no luck. This scratch is on a black car and appears to just be the clearcoat. I was able to remove some other subtle scratches with the pink pad just not this one. Here is the RAM, Ill get the car up later.
    Attached Thumbnails Attached Thumbnails The first of two scratches I would like to fix-cam00172-jpg
    Aug 2010
    New Jersey
    15,196
    Re: The first of two scratches I would like to fix
    If it catches your fingernail, you might want to think about filling it with touchup paint before you sand anything, lest you be saddened further.
    Super Member mfrickman's Avatar
    Mar 2013
    Raleigh, NC
    313
    +1 all day every day. If you are new to wetsanding, do yourself a huge favor and get a panel from a junkyard. I've seen numerous threads on here where guys try to wetsand and end up compromising clearcoat.
    Also, if you can't catch your fingernail, swing by a local auto parts store and pick up some Meguiar's Ultimate Compound. If you don't already have any compound of course.
    Sent from my SCH-I545 using AG Online
    Mike Frickman
    Owner/Operator
    On Scene Detailing
    Jul 2012
    94
    get touch up paint, a tooth pick and 3k paper and a block.
    use the tooth pick to "fill in" the scratch. do several coats or multiple strokes waiting 20-30min in between each time.
    you are essentially filling up the scratch, once filled you are going to block sand the whole area with 3k paper.
    The paper will sand off excess paint and sand offf any paint the is not "in" the scratch. There is a how to thread on this by Mike Phillips.
    so you are left over with just paint in the scratch, the WG TSR will sand off 3k paper marks so dont worry about that.
    so you are filling, leveling off extra paint and than buffing to a shine. expect to spend a good 24hrs doing this. (you need to allow the paint to dry in between fillings)
    as stated, goto a junk yard or body shop. get a old panel or hood, whatever. scratch it similar to what you are dealing with no and see how it goes fixing it.
    post ?'s and perfect your craft before you try it on your car.
    GL
    Super Member HateSwirls's Avatar
    Jun 2013
    3,632
    +1
    Great way to do it, I prefer using 2k first than 3k un-grit.
    Then polish it out to perfection
    Quote Originally Posted by Rival View Post
    GL
    Super Member hernandez.art13's Avatar
    Apr 2013
    6,958
    http://youtu.be/6xi3xmeO6C4
    http://youtu.be/jmEhsuO2cKY
    http://youtu.be/v5QAjWbx03s
    And as they suggested, practice and get it clocked in first. (If done improperly you can cause additional damage)
    You can always find a Reputable Detailer that could take on the task for you. He can also show you proper care for the work he does.
    ^ (Check out those videos a lot of additional information)
    Good luck, and ask as many questions as you like before tackling this job IMO
    Art
  1. Video: Rotary Buffer - Removing sanding scratches - Full Headlight Correction - Remove Hologram Scratches
    Last Post: 02-03-2019, 12:30 AM
  2. Scratches from ice
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 11-19-2014, 11:06 AM
  3. How to remove scratches in glass - Wiper Scratches from Beach Sand
    Last Post: 04-11-2014, 05:02 PM
  4. a few scratches
    By Dan_335i in forum Wet-Sanding, Cutting & Buffing
    Last Post: 02-07-2014, 07:32 AM
  5. Replies: 9
    Last Post: 01-29-2013, 06:37 AM
