Re: Porter Cable and Color Sanding
What part of LA do you live in?
I wish i had a dewalt it was the shops dewalt
I bought the poor boys porter cable kit, but went and bought a wool pad, and 3M compound. I also bought 1000,1500,2000,2500 wet sand paper and bought 3M 3000 disk sand paper that I planning on using with the porter cable. Hopefully it'll work.
Does anybody know if it will?
I worked in Perris, CA but I am currently living in La Puente, CA
Where are you David?
I'm in the southbay area. Torrance.
The wool pad will not work on the porter cable. Not enough power
Sent from my SGH-T999 using Tapatalk 2
Dammit... What foam pad will be equivalent to a wool pad?
Wool pads just feel so normal and natural to me. Oh well...
Will the one that came with the kit work?
CCS Orange 6.5 inch Light Cutting?
Or which color?
This is the next one. Just one step lower not bad.
CCS Yellow Cutting Foam 4 Inch Pad - Use this pad to apply compounds or polishes to remove severe oxidation, swirls, and scratches. It is the most aggressive and should only be used on oxidized and older finishes. Always follow this pad with an orange or white pad and a fine polish to refine the paint until it is smooth.
Are we allowed to talk about our local auto paint shop? Or is it no no?
I damp sanded with Meg's unigrit and foam backing, went up to 3000.
Removed sand marks with Meg's MF System, all with DA.
Go to Meguiars free classes in Irvine.
Oops, I see already covered on pg 1
Meguiars has free classes in irvine???
Wow...!
I'm sure the info is on there website.
By KenRobertson in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-21-2017, 11:24 AM
Last Post: 12-14-2013, 09:10 AM
By kingweb50 in forum Wet-Sanding, Cutting & Buffing
Last Post: 11-17-2012, 12:58 PM
By Jrgs-r in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-15-2011, 04:22 PM
By BADZZHUMMER in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-25-2006, 08:23 PM
