Holograms in my BMW X5
Anyone got any suggestions of removing holograms from BMW's rock hard clear coat?
I have tried Pinnacle Advanced Swirl Remover, Pinnacle XMT Swirl remover #3, Meguiars Swirl Remover, 3M Swirl Remover, and Optimum Hyper Polish spray. All with Lake country Orange and Yellow cutting pads with my Flex 3401 polisher.
These things won't budge.
Anyone got any other suggestions?
Re: Holograms in my BMW X5
Menzerna SIP on an orange ccs. followed up with 85rd on a white. Jewel with 85rd on a black with a rotary for maximum gloss.
Jon Miles
Possibly not the products........are you working on a small enough area? Are you applying enough pressure to the machine to work the polishes properly? What speed are you working at? Those are things to consider before you go purchase another product!
Hey thanks. I'm pretty sure I'm using them correctly. I have been successful in removing swirls and blemishes on other vehicles. Just can't get them out of my own car. I will lower my work area and apply more pressure. The Flex is on speed 5. Anything else you suggest?
Are you sure they are not RIDS and, thus, deeper? Is there any improvement after each pass? Was there any improvement after the first few passes? What color is the car? Most BMWs I have worked on have medium to soft paint.
I would not use orange or yellow pads with swirl removers. Step up to M105 or something more aggressive. Keep the orange and above pads to compounds, and use softer pads for the swirl removers (like white or black).
So the holograms can be getting introduced with your aggressive pads. You could be correcting some and adding others. Or the polishes are just too fine for the paint and defects. Try the swirl removers with a black pad and see if the surface improves. If it does, then you are probably adding holograms with the yellow pad. If it does not, then you will need something more aggressive polish-wise for the hard paint. Either way, change to a compound with the orange pad, then back to the black pad with the swirl remover.
Local to Southeast Michigan
Serving Nationwide
Of the polishes you have listed I'm pretty sure the Pinnacle ASR has the most cut. If that is not working then you need to go more aggressive. SIP is very good on hard clearcoats but if ASR isn't "budging" like you said, You will need more aggressive than SIP! Perhaps Power Gloss Compound or 105. Megs Ultimate Compound is very similar to 105 and is available locally!
Try Megs UC and an orange pad.
jlb, you can induce holograms with a 3401?
Do you have any pics of the problem? It would really assist in laying out a gameplan to remove the problem for you.
Jon Miles
Sorry but I have a question about holograms, can I make them with DA or it only happens with a rotatory?
By chuckk in forum Auto Detailing 101
Last Post: 01-03-2016, 05:18 AM
By MstrJosh in forum Auto Detailing 101
Last Post: 07-25-2015, 12:07 AM
By SN95Sam in forum Ask your detailing questions!
Last Post: 07-31-2013, 11:52 AM
By Nate3420 in forum Auto Detailing 101
Last Post: 06-03-2013, 07:08 PM
By 93fox in forum Ask your detailing questions!
Last Post: 02-07-2011, 10:20 AM
