Results 1 to 5 of 5
    Super Member oldmodman's Avatar
    Sep 2007
    2,563
    Can the Meguiars Unigrit 3" foam interface pad be used with 3m products.
    I have most of the 3M Hookit II foam sanding pads and I would like to use a foam interface pad.
    Is the Meguiars hook & loop on their foam interface pad compatible with the 3M hook and loop on their 3" adapter and on the 3M Trizact Hookit II foam sanding pads.
    I'd just get the 3M pad but it's only available here in the 6" size.
    Re: Can the Meguiars Unigrit 3" foam interface pad be used with 3m products.
    Can be used together
    3M 3" Hookit Backing Plate
    Meguiar's 3" Interface Pad
    Cannot be used with the Meguiar's interface pad
    3M 3" Hookit II Backing Plate
    Full article here...
    The difference between 3M's Hookit and Hookit II Hook-N-Loop Interface Systems
    On the left hand side is the 3M 3" Hookit Backing Plate and just above it is the Meguiar's 3" Interface Pad, these two items are Hook-n-Loop Compatible. You must use Hookit discs with the Hookit Backing Plate. The Hookit system follows the industry standard for hook-n-loop interfaces.
    On the right hand side is the 3M 3" Hookit II Backing Plate, the Meguiar's 3" Interface Pad will not work with this backing plate. You must use Hookit II discs with the Hookit II Backing Plate. The Hook-n-Loop is reversed on this 3M system.
    Hookit II Backing Plate with "Loops" on the backing plate
    (Reversed Hook-n-Loop System)
    Close-up of the "loops"
    3M 3" Hookit Backing Plate with "Hooks" on the face of the backing plate
    (This is the industry standard system for hook-n-loop interface)
    Here you can see the J-Hooks - Note there are different designs of hooks, not just the shape of a "J".
    Note: If you've ever noticed over time that your pad and backing plate don't attach as firmly as when they were first new, it's because over time the "hooks" will tend to straighten out from use and thus won't hold the loops as tightly.
    Probably more than you ever wanted to know about hook-n-loops...
    Super Member daveinsweethome's Avatar
    Jan 2010
    sweet home, oregon
    476
    some of the close ups look like an alien movie bad guy.
    Sep 2007
    2,563
    A second question just dawned on me.
    Hook and loop has a "male" side, and a "female" side.
    If the Meguiars interface pad has a male and female side can't you just turn it over? Since the Hookit II has a male & female side also. Unless the actual hooks and loops of the two different manufacturers are incompatible it "should" work. Kinda like wife swapping, it's frowned upon, but the parts should still work just fine when traded around.
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    Quote Originally Posted by oldmodman View Post
    Except that you'd have a problem connecting any abrasive discs to it other than Hookit II discs.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  1. Meguiar's Unigrit Foam Finishing Disc
    By Lustrous Detail in forum Products Guides
    Last Post: 08-06-2015, 09:09 AM
  2. Unigrit 3" Sanding Discs
    By BitterGreg in forum Auto Detailing 101
    Last Post: 06-06-2015, 03:34 PM
  3. Meguiar's Unigrit 3" discs
    By EVOlved in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-27-2014, 05:33 PM
  4. Meguiars Unigrit 3 Inch Finishing Discs
    By AeroCleanse in forum Ask your detailing questions!
    Last Post: 05-11-2010, 11:32 PM
  5. Meguiars Unigrit Sanding Block
    By Rsurfer in forum Auto Detailing Tools and Accessories
    Last Post: 05-19-2009, 12:32 PM
