Results 1 to 9 of 9
    Apr 2009
    Long Island NY
    55
    Wet sanded door and Fender
    Well the weather finally broke and warmed up enough for me to wet sand the orange peel that was on the rear door and fender where a "professional" body shop re-sprayed a few months ago. I had brought the truck back to them and they were suppose to fix it but they didn't so I decided to do it myself. I washed the area and then hand sanded the area starting with 1500 grit then went to 2500 and finished with 3000. I then used a wool pad with the new mothers heavy duty rubbing compound (which is awesome) and then polished the area using menzerna po 83 using a white pad and then followed that with menzerna po 85u using a gray pad I finished up by applying wolfgang 3.0 deep gloss sealant. I ran out of time so when the weather gets nice again I will finish polishing the rest of the truck and then wax it. This pic was of just the rear door after I wet sanded it and compounded it using the mothers compound sorry about the pic of was from my phone. I will post more pics when the weather gets nicer its been raining on and off all day.
    Attached Thumbnails Attached Thumbnails Wet sanded door and Fender-wet-sanded-door-jpg
    Junior Member the_invisible's Avatar
    Sep 2009
    72
    Re: Wet sanded door and Fender
    Looks cool dude. I really enjoyed wetsanding as well. It was a fun and rewarding process. But looking back at the amount of work required, I don't think I will be doing it again.
    Newbie Member Streamlinekusto's Avatar
    Apr 2010
    I couldnt help but noticr that ther are still sanding marks tward the bottom of the door, are you going to compound it some more before you seal it?
    Super Member Fly bye's Avatar
    Nov 2007
    789
    Good work eh.
    Nov 2007
    789
    Nov 2007
    789
    Quote Originally Posted by Streamlinekusto View Post
    Quote Originally Posted by LITUNDRA View Post
    Mar 2006
    SW Florida
    381
    I think I'm missing something?????????? It's been compounded, and sealed???????
    Apr 2010
    the picture just looks like the door still has sanding marks
    Apr 2009
    Long Island NY
    55
    haha sorry I should have been more clear, you are right in that picture I had only compounded the upper half of the door so the bottom part of the door still needed to be done it was more of a 50/50 shot to show you how the mothers compound finished up. I did however compound the rest of the door and the rear fender right after I took that picture but unfortunately the clouds rolled in right after I had finished and the pics I had taken to show off all my hard work looked like crap because I have been to lazy to get a new camera so I did not post them.
    Yeah it is a very rewarding process but wow was it a lot of work, the door and the rear fender took me almost 4 hours from start to finish I probably could have skipped a few steps and still ended up with the same result but oh well live and learn right.
  1. Cleaning Fender wells (liner under the fender)
    By TNMIKE46 in forum Auto Detailing 101
    Last Post: 01-23-2019, 04:15 PM
  2. Reflections on my wet sanded SUV!
    By corky5678 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 10-30-2014, 03:10 AM
  3. I think I wet sanded too much...
    By xof in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-11-2013, 10:46 AM
  4. Cleaning the felt between door and door panel?
    By nissenc1337 in forum Auto Detailing 101
    Last Post: 04-01-2013, 05:08 PM
  5. Sanded down too far...
    By robollama in forum Auto Detailing 101
    Last Post: 09-13-2011, 08:13 PM
