Results 1 to 5 of 5
    Apr 2021
    Need Advice - Grey looking paint when it should be black
    Hi Everyone,
    I am new to the forum and would greatly appreciate some advice. I was doing some 1200 grit wet sanding on my gloss black alloys to smooth out some old touch up paint and noticed that the black paint turned a cloudy grey which i know is normal from wet sanding. I then used some rubbing compound to remove the scratches left behind but there are still grey patches which I can’t remove and just gets worse the more I use compound on it. Please see the attached photo.
    I thought initially that the reason why it turned grey is because it could of been old touch up paint which wore very thin from wet sanding but this doesn’t seem to the the case as the grey patches just get bigger. If anybody can please shed some light on this I would be most grateful!
    Thanks
    Reece
    Attached Thumbnails Attached Thumbnails Need Advice - Grey looking paint when it should be black-aa79fba2-f092-409e-b0c4-bdf1517912b3-jpg
    Re: Need Advice - Grey looking paint when it should be black
    First...
    Welcome to AutogeekOnline!
    Second - from the picture, I still can't make out the issue?
    The big picture is this, you might end up simply re-painting the entire wheel to get it to look uniform.
    Apr 2021
    Hi Mike,
    Thanks very much!
    The issue is the grey looking paint within the red circle. It should be black colour and gets worse when using rubbing compound. Any ideas why the paint has turned grey?
    Reece
    Quote Originally Posted by Rhughes92 View Post
    Hi Mike,
    Thanks very much!
    Reece
    Do you see black coming off the wheel and onto your cloth?
    When you abrade clearcoat - you make it grey.
    If you're pulling color, maybe you've buffed through the black layer and are now working on primer?
    Hard to say without being there. That's why I wrote about the BIG PICTURE. It could be that you're past the point of no return with the finish on this wheel and at this point - it's time to rattle can it.
    Mar 2015
    723
    Road rash/curb take off the black paint?
  1. 1990 GM Black Paint - Advice needed
    By Trevine in forum Ask your detailing questions!
    Last Post: 02-07-2019, 11:12 PM
  2. Request for advice - Porsche 911 Jet Black paint
    By DoubleDare in forum Auto Detailing 101
    Last Post: 03-13-2018, 06:38 PM
  3. Replies: 14
    Last Post: 06-02-2017, 09:17 AM
  4. How to remove grey-black scratches from white paint?
    By niegrau in forum Auto Detailing 101
    Last Post: 07-21-2013, 02:55 PM
  5. Your advice for a super soft black Honda paint
    By zckid in forum Ask your detailing questions!
    Last Post: 06-11-2011, 12:07 PM
