Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 66
  1. #31
    Mar 2021
    Encino, CA
    32
    Re: Need advice - Oxidized Paint Correction on 1968 Dodge Charger
    Need advice - Oxidized Paint Correction on 1968 Dodge Charger-391df5d0-6036-4295-b654-274da4083736-jpgPic
  2. #32
    Looks GREAT!
    Thanks for making the YouTube video also...
  3. #33
    Mar 2021
    Encino, CA
    32
    it does! Much appreciated, Mike! About to comet wash the rest of the car.
  4. #34
    Mar 2021
    Encino, CA
    32
    The paint looks amazing after the Meguiar’s #7 rubdown.
    Wonder if it will stay this nice or revert in a few days as the oils dry or dissipate?
    I suppose I should wait a few days and take it out in the sunlight, but is there a world where I leave well enough alone and not do the 3D One/Rotary/Wool pads and just skip to the Blackfire One Step?
    I’m guessing it’ll still be smart to do the rotary/wool
    Pads step, but I’m just very impressed by how much better it looks after wiping off the #7.
    Thanks, Mike!
    Need advice - Oxidized Paint Correction on 1968 Dodge Charger-9c46e51c-61e6-49b4-933f-722f270721c0-jpeg
    Need advice - Oxidized Paint Correction on 1968 Dodge Charger-4ecf58f6-92dd-430e-adc2-7304518c2f96-jpeg
  5. #35
    Mar 2021
    Encino, CA
    32
    Video of Charger after Meguiar’s #7 rubdown/removal.
  6. #36
    Super Member TMQ's Avatar
    Mar 2015
    Germantown, Md
    2,243
    Skip rotary and go straight to DA and Blackfire One step....Done.
    If you feel megs #7 is dry during wipe off---do another application and another 24 hours.
    I have done as much as 5 to 7 applications before DA'ing the paint with a One step.
    If megs is wet after 24 hours---means oils from megs have completely filled the paint and the paint no longer can absorb any more of the megs oils.
    Then go ahead and do light cut with One Step....
    Tom
    Mr Tommy's
    Wash, Buff, Wax
    Website: mrtommyshine.com
  7. Likes dgage liked this post
  8. #37
    Mar 2015
    Germantown, Md
    2,243
    And no---it won't dry out.
    You'll be good for a long time.
    Tom
    Mr Tommy's
    Wash, Buff, Wax
  9. Likes dgage liked this post
  10. #38
    Mar 2021
    Encino, CA
    32
    Gotcha, thanks Tom! Oddly enough the passenger side of the car feels a little wetter than the driver side. Maybe I’ll add more Meguiar’s to the driver side.
    I wonder if it has anything to to with the fact that I’d already done some half-hearted buffing with a DA on the passenger side, but the driver side only went through clay bar and comet wash.
  11. #39
    Hi Ted,
    Tom is correct.
    Here's the deal, #7 is water soluble. It's not an abrasive product and it's not a product to SEAL the surface, like a wax, sealant or coating. So after you're finished with the #7 Rub Down Technique - Machine apply "something". The BLACKFIRE One Step would be a great choice as besides sealing the paint it will remove other paint defects like swirls, scratches and more oxidation.
    I would NOT recommend using a rotary buffer at this point. Stick to any brand of free spinning random orbital polisher like the Porter Cable. Use a foam polishing pad and turn that sucker up to the highest speed setting and then start making section passes.
    DO start by doing a Test Spot and make sure the end results look great. Some old single stage paint simply doesn't like to be abraded with any brand of anything - thus the reason you do a Test Spot BEFORE buffing out the entire car. If your results from the Test Spot don't look great - at least you only have to fix the test spot area.
    If you buff out the entire car without knowing the results and the results are bad - now you have to fix the entire car.
    Make sense?
  12. #40
    For everyone that will read this thread into the future,
    Here's a video Yancy and I like and it covers EVERYTHING related to using Meguiar's #7 to restore antique, original single stage paint.
    Easily the BEST video on this topic anywhere in the universe.
  1. Replies: 26
    Last Post: 10-14-2014, 08:16 AM
  2. 1968 Dodge Charger R/T - Anthony's Auto Detailing in Clementon, NJ
    By Anthony Onorato in forum Show N' Shine
    Last Post: 08-25-2014, 05:37 AM
  3. Replies: 21
    Last Post: 04-18-2014, 09:38 PM
  4. 07' Lime Dodge Charger a.k.a Dodge-Zilla! (pics and vid)
    By Wills.WindowsAndWheels in forum Show N' Shine
    Last Post: 11-05-2011, 12:44 PM
  5. 1966 Dodge Charger Exterior Correction
    By Auto Concierge in forum Show N' Shine
    Last Post: 04-23-2011, 08:07 PM
