Re: Need advice to remove 2000 grit sanding marks
Great info, thank you, Mike! Yes, I am pushing hard, so that makes sense it is the fibers of the wool pad. I guess The boat has to wait...
Just to add: lighten up your pressure towards the end of the buffing cycle with the wool pad. You can use CutMax and a cutting Foam pad after the wool and it should give you the clarity to see if you left any sanding marks.
Last Post: 04-23-2019, 08:50 AM
Last Post: 12-19-2017, 05:30 PM
By Honda Enthusiast in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-03-2017, 06:45 AM
By cpdetail in forum Wet-Sanding, Cutting & Buffing
Last Post: 10-19-2016, 10:46 AM
By zckid in forum Auto Detailing 101
Last Post: 03-07-2012, 08:26 PM
