Results 21 to 30 of 33
  1. #21
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Re: spotting under brand new black car paint
    It's not that different here. The manufacturer reimburses the dealer for the warranty work. We've been through some ups and downs with that, at one time GM, for example, paid the dealer a fixed rate, regardless of what the dealer labor rate was. If the dealer labor rate was higher than what GM was paying, the dealers would tell customers things weren't covered by warranty. After a while GM started getting a bad rep and they started reimbursing at the dealer labor rate.
    As far as the cars not sitting on the lot...it used to be like that here, you ordered a car from the factory if you were a car guy, to get just what you wanted. But when imported cars began to become really popular here in the late 70's and early 80's, it of course wasn't feasible to order a car from the factory, so those dealers began to stock large numbers of cars on their lots, so they would have a large selection of colors and options. After a while the US companies started to streamline the multiple options into just a few option groups, because customers had become used to the idea of whatever they needed "being on the lot", so even the dealers for US brands typically have very large inventories and it's less common to order a car. At least that's the way it looks from where I sit.
    While I agree with you, I think this is beginning to change.
    I took the lot/driver job for my small dealership on 6/11 of this year, and I have been on at least 50-60 swaps from New Hampshire, to Maryland and points closer.
    I am also seeing more factory orders coming off of the trucks. 99% of these are top of the line vehicles. Just my experience at my job.
  2. Likes SWETM liked this post
  3. #22
    Aug 2010
    New Jersey
    15,305
    I still try to order my cars...but last one I bought was a leftover, so it's been a while. But you're also making my point--don't the dealers do swaps so they don't have to order a car for the customer?
  4. Likes PaulMys liked this post
  5. #23
    Jan 2014
    Eastern L.I. NY
    10,772
    Yes, you are right.
    My point was the customer wanting something else than was on the lot, but a swap for what they want makes the dealer a bit more coins.
    I received 7 new F-150's just today off of the haulers. 3 were factory ordered (Sold).
  6. Likes SWETM liked this post
  7. #24
    Aug 2010
    New Jersey
    15,305
    I think we're in the same place...I'm just not as up to date as you--back some years ago, before everything was so networked, the individual dealers had to keep a larger inventory, but now it's easier for them to locate a car at another dealer, so they can leverage that to not keep as many cars on hand, although I'm sure the larger dealers try to because it's in their interest to be the place that other dealers need to get a car from.
  8. Likes PaulMys liked this post
  9. #25
    Oct 2018
    Halogen lamp keeping the surface around 160-170 deg F for 3 hours did nothing to the spots.
  10. #26
    Super Member JKDesign's Avatar
    Oct 2016
    Portland, ME
    316
    It does look similar to moisture trapped in the clear coat to me. This happens from time to time while the vehicle is in transit with the plastic wrap on it- being exposed to multiple temperature differences while on the road can cause the spots to appear. I have seen vehicles with entire roofs or hoods that were milky looking once the plastic wrap was pulled off. Best solution is to use a heat gun and and slowly work it out. Once it is out it is out- there is no worry of premature failure or delamination of the paint. In my shop we have tried using the infrared lamps but they tend to fail to get it out- heat gun is where it is at.
  11. #27
    Oct 2018
    I will try that. Any idea what you were getting the surface temperature up to or what heat range you were using on the heat gun? How long did you have to pass it over the surface? I'm just wondering-if it is going to work, how long until I should see improvement before I say it's not working or not.
  12. #28
    Aug 2010
    New Jersey
    15,305
    Boy, be careful with that heat gun, especially if that's a plastic panel.
  13. #29
    Oct 2018
    It's steel front fender. I will definitely be extremely careful which is why I asked my above questions.
  14. Likes SWETM liked this post
  15. #30
    Aug 2010
    New Jersey
    15,305
    I'll defer to JKDesign, but I don't think that's moisture--even he said "milky" and that's what I've seen in other instances of moisture trapping, a more uniform defect (here's an active thread on the other forum right now: Interesting Paint Defect ).
    It looks to me more like some sort of solvent trapping...which of course might be cured in the same way...I'd just be worried about those "bubbles" "popping" if you heat them up. I appreciate your perseverance and caution, though.
  1. Replies: 62
    Last Post: 08-08-2020, 02:08 PM
  2. Brand New Black Car
    By nymickey in forum Ask your detailing questions!
    Last Post: 01-04-2018, 09:00 AM
  3. Nissan Soft Paint small dots spotting. Help identify.
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 10-09-2016, 08:55 PM
  4. Beware of Subaru's brand new black paint!
    By andrew8729 in forum Show N' Shine
    Last Post: 01-16-2014, 11:16 PM
  5. Brand New Black Paint.
    By Stype4life in forum Pinnacle Wax
    Last Post: 08-27-2010, 01:05 PM
