Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 63
  1. #41
    Aug 2015
    263
    Re: Fell for the sales pitch - Griots Garage Orbital
    Quote Originally Posted by rduchateau2954 View Post
    Well lemme ask you this; if I'm going for maximum oomph wouldn't a 3" backing plate and cutting pad be the way to go?
    Don't get me wrong, I really appreciate the offer, I'm just trying to limit how much more money I stick into this in case it's all for nought.
    Thanks,
    Ryan
    Sent from my SM-G965U using Tapatalk
    I use the Boss 3" backing plate and pads on my GG 6" DA polisher. I find that it gives a lot more cut than the 5" pads. I have a black MB with rock hard paint and I find 3" pads (MF pads) cut way quicker than the 5" pads. Depending on how serious your defects are they may or may not get them, but I find the 3" to give a lot more 'oomph' than the 5" (and definitely more than the 6") pads.
  2. #42
    Jul 2018
    Quote Originally Posted by boomdone View Post
    Maybe I'll bite the bullet and try those. Even if that doesn't take out the deeper part of the scratches how it performs on the shallower bits will tell me if wet sanding could be done.
  3. #43
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    That's possible. The problem I'm having right now is trying to decide what to do.
    Option A) Return the machine, eat the shipping costs, and give the pads and compounds away. $250 ish dollar initial cost, I'd get $150 of that back minus shipping. Although part of that $250 was wax.
    Option B) Keep it, throw more money at in in pads, backing plates, compounds, and hope they work.
    Option C) Put it all in a box, put the box in a corner, cry for a bit, and order a rotary setup.
    Reading the last couple of responses you've written, your like of 3M, not using off the shelf products, etc, I'd like commenting some more.
    As for polishes, I've basically used Menzerna, and Woflgang Polishes, which I understand the Wolfgang Polishes are made by Menzerna. Their Polish line is quite vast.
    And I have little doubt that with the Griots D/A, and the right size aggressive Pads and Polishes, you could no doubt polish the clear coat right off your truck, and perhaps most of the color coat too if you worked long enough at it. On occasion
    I've used Meguiars #205, but #205 is an ultra finishing last step polish, not suited for removal of more severe defects.
    Sort of like Larry in the 3 Stooges when they were the Pip Boys, had a tailor shop, and Larry thought the mark on the pants was a stain, rubbed till he rubbed a hole right through the pants, and the mark was still there. Then he found out it was a ray of light shining through a window, and not a stain! Duh!
    Sometimes, damage is severe enough, and deep enough, that no process, no product, and no tool will remove it, or remove all of it. And there's no Wax, Sealant, or Coating made that will protect the paint from things like I had happen to my last beater car, such as a cardboard box flying across the road at 40mph in a windstorm and hitting the backside of the car, or running headlong 65mph colliding into a tumbleweed the size of a giant Beach Ball doing 40mph on I-25 just south of Albuqueque, NM one afternoon.
    In both instances, the damage went though both the clear coat, and color coat, nothing one can do but do the best you can to repair, and count your blessings I reckon that it wasn't worse, or worse yet, an accident.
    I'd say before making a call, sleep on it some more. I believe the Griots 6" can serve you quite well once you fine tune processes and accompanying accessories, to then at least acquire a smaller 5" Backing Plate, a host of good Polishing Pads, such as the Lake Country Thinpro in their various colors-aggressiveness are very good.
    And to acquire perhaps a couple-few more Polishes, one that perhaps may be more capable of addressing more severe paint damage. Probably the Menzerna FG-400 might be a good one. Compounds such as Meguiars #105 can commonly be gotten at the big box auto parts stores, and even some wally worlds carry it.
  4. #44
    Jul 2018
    Quote Originally Posted by MarkD51 View Post
    I'll have to do some research on menzerna vs 3m. I hear y'all talk about it a lot.
    The frustrating part about this is that I know with 100% certainty, with the exception of maybe the initial impact, I could get this out if I was in the shop with my rotary.
    It's like the tiny coffee stain under my cup holders, if I had my extractor it would be gone, but the little Bissell pos shampooer I have from potty training my dog isn't up to the task.
  5. #45
    Oct 2012
    Sheboygan Wisconsin
    3,130
    The Menzerna Polishes are all of extreme high quality. Just a few from their line-up should cover most bases with anything that comes at you as far as paint correction needs.
    Meguiars makes many fine polish products, as I understand 3M bought Meguiars a few years back. Problem with Meguiars often, is that when you walk into any auto store, or paint supply shop, you might only find a very limited selection. They carry a quite vast line of detailing products, many I was not even aware of and been a member here a good number of years. (#101 and #205 are both exemplary polishes)
    The store here carries mostly all of them.
    I don't believe any of the Menzerna Polishes (or Wolfgang-Blackfire) contain any fillers, so what you see is what you get, and not like some of the crap the car dealers use at current day, where a used vehicle looks great the day you buy it and drive away, and then the first wash after looks like swirl city.
    I think one major aspect of your dislikes of the Griots D/A, is not yet getting fully dialed in with the right Pads, Plates, Chemicals, and learning-acclimating to this new tool. Many say the Griots 6" machine is a better choice than the Porter Cable because it possesses a more powerful motor.
  6. #46
    Mar 2016
    RD check your pm's. I sent ya one.
  7. Thanks rduchateau2954 thanked for this post
    Likes rduchateau2954 liked this post
  8. #47
    Jul 2018
    Hopefully picking up a Milwaukee rotary this afternoon.
  9. #48
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Fell for the sales pitch - Griots Garage Orbital-dscn0699-jpgFell for the sales pitch - Griots Garage Orbital-dscn0697-jpg
    As a reminder, and as you probably already know well, an aggressive compound usually doesn't finish down LSP ready. Meaning a simple follow-up with a finishing polish is all.
    Perhaps depends what product? Wolfgang Uber Compound is as its name states, a so called compound, but this one does finish down oh so nicely I've found. This one's always now in my personal arsenal of products.
    There's different abrasive technologies, some are referred to as "DAT", (Diminishing Abrasive Technology) some are referred to as "SMAT" (Super Micro Abrasive Technology), and some I believe are even a hybridization-combo of the two.
    DAT breaks down from larger clusters into smaller micro particles, starts out more abrasive then breaks down finishing well in its working cycle. SMAT will start with various size abrasive particles per formula, and doesn't break down through its working cycle,
    I'd suspect your previous attempts with the Griots D/A only gave you what could be called a "glorified wax job" was all. Meaning you probably haven't done much in the way previously, of knocking down or diminishing much of the thickness of the clear coat to be much concerned about.
    When I first got my Porter Cable D/A here from Autogeek and all the goodies to go with about 5 years ago, I knew jack about these newfangled D/A machines, never used one quite like them. I wasn't about to break it out first on my beloved Tahoe SUV, but had commonly used most, if not all the products, tools, and processes I've ever bought here on my once owned shitbox 2001 Kia Spectra instead.
    The first time I did the Kia, with Wolfgang Total Swirl Remover, I only had a smaller backing plate and a few small 4" Pads to test. Got pretty good results, a striking difference from before, but as I found later, still no cigar cause I was still a cherry with this tool, and the combo of products, was still learning the ropes so to speak.
    The second time around, re-thinking, studying some more, re-fining technique, and processes, I got better considerably. I wasn't about to give up, and I feel today it has all paid off.
    After I began getting the results I sought, I had seriously considered selling my mint boat anchor Milwaukee Rotary. Put in on a local classifieds twice, and yanked the Ad twice, with the thought I'd be losing good money for what I paid for it, and that one day I might regret the sale, that I'd be needing it for some special purpose.
  10. Likes rduchateau2954 liked this post
  11. #49
    Jun 2013
    Montreal, Quebec
    3,996
    For deep scratches like that, nothing beats wet sanding. You can take them out with a rotary polisher, but you are removing a lot more paint than you need to and you run a risk of burning through. Otherwise, when talking about removing swirls and very light scratches, the Long Throw Dual-Action polishers and the forced rotation polishers should give you a better result than the rotary. If you purchased a short throw one, then it will give the same result but it will take more time.
    As for the ability to take out wet sanding scratches, that is completelly true. My main polisher died last month, I had to switch to my backup (Porter Cable) that is one of the weakest DA you can buy. I was able to remove 1500 grit sanding marks without effort using Meguiars Microfiber cutting disks and Meguiars D300 Compound. That compound is actually an AIO, it has very good cut but not as agressive as M105 or other super heavy cut compounds. I have never tried removing 1000 grit sanding marks but considering the ease to remove the 1500 ones, I would not be surprised it could be done without too much effort. Especially on a powerful machine like 21mm throw or forced rotation.
    Remember there is a learning curve to everything. You mastered the Rotary, now you need to take the time to master the DA. I have a rotatry polisher (Dewalt) sitting in my toolbox and I never use it. I do need to get training on it, cause everytime I try to use it, I find it much less effective than my DA and I know I am risking damaging the paint which is not the case with my DA. After some training, I am sure I would like it, but again, all the years of experience I have on the DA are pretty much useless on the rotary. So we are in the same situation, just with opposite tools
  12. #50
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    3m polishes and compounds are really good. Are they the best?? That’s an opinion but there are better in my opinion. Newer compounds will cut better, dust less, have a longer work time and finish better.
    3M Ultrafina is a special one tho. It’s my favorite final finishing polish(jeweling polish for those that prefer that term).
    To the OP. If you can properly use a rotary and that’s what u prefer then by all means get one. But I suggest be open minded about using other machines. There are instances where one tool is better than the other. So it’s nice to have available options. It’s nice using a DA sometimes as it usually only requires one hand operation say for something like using just a paintwork cleansing lotion or a follow up polishing after a compounding.
    Jim
  13. Likes fly07sti liked this post
  1. Griots Garage 5 inch Lithium-Ion Random Orbital Polisher
    Last Post: 08-20-2018, 08:23 AM
  2. Replies: 5
    Last Post: 11-05-2016, 08:33 AM
  3. How do you even respond to this sales pitch?
    By Fishincricket in forum Off-Topic
    Last Post: 04-23-2013, 07:34 AM
  4. My sales pitch
    By hernandez.art13 in forum Auto Detailing 101
    Last Post: 04-21-2013, 12:59 PM
  5. Griots Garage Professional Random Orbital 3 Inch Polisher
    By Johny B in forum Ask your detailing questions!
    Last Post: 07-27-2012, 06:36 PM
