Re: Rotary VS Dual Action for Compounding
Originally Posted by
Joel1979
Do you have any with lambs wool pads??
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
Ronin47
It can level defects faster without burning paint. Leveling a defect and burning through are two different things, burning is excessive heat which is not related to cut.
Sanding a piece of wood and setting it alight are different things, both generate some form of heat, get the picture?
Interesting...the term burning the paint. The pads on DAs get a lot hotter than on a rotary.
Ronin47
So an operator must be more conscious about clear levels using a DA than with a rotary because it can cut through clear faster?
DaveT435
But the paint dont get as hot.
Joel1979
bro, I probably would've thought the same thing a few years ago... but as a heads up turning the speed of your rotary to "almost max RPM's" doesn't equate to more correction.
Also, while I love foamed wool pads their cut is more like foam and less like wool.
Joel1979
We aren't using error in this discussion, so assume the operator knows how to use a rotary and doesn't heat the paint beyond damage.
mwoywod
Faster than cutting with a rotary? I believe that the 21 MKII offers the more correction than a rotary on open flat panels, but the 21mm orbit still makes it completely impractical for correcting every surface on most modern vehicles. Unless you're working out of a body shop and all the panels are disassembled? If not, I assume you're using a multi-tool approach which for me takes a lot more time.
21 MKII with 5” Kamakazi Beast bp and experience can be a one tool only, but I use the Mille with the 5mm orbit and Rupes Mini also.
Joel1979
Nice factual link right there. How you finding Resurrection? I like Redemption.
jslym777
MKII still faster and more powerful.
https://www.instagram.com/p/BQFyFLYDSK_/
This kind pad is the pad to use with rotary if you want most cut, but then the finish also sucks and you might have to do 3 steps.
