Thanks Thanks:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Super Member YankeeFan's Avatar
    Join Date
    Dec 2006
    Posts
    607
    Post Thanks / Like
    Polish wipe down quick question
    So frustrating after searches not being able to find the answer to a question I know is out there
    Anyway, as you wipe down after polishing an area what do you use? IPA, Mineral Spirits, etc? Are these solvents the mainstay everyone uses or are they too harsh to use throughout the polishing process
  2. #2
    In time out
    Join Date
    May 2016
    Posts
    745
    Post Thanks / Like
    Re: Polish wipe down quick question
    I use to use 50/50 alcohol with distilled water. But I switched over to Eraser. A product CarPro puts out.
    I find it has more lubrication than a IPA. Lots of companies make products for removing polish oils and paint prep.
  3. #3
    Super Member Mike Honcho's Avatar
    Join Date
    Apr 2015
    Location
    Atlanta
    Posts
    1,264
    Post Thanks / Like
    Interesting thought. I just use a dry towel. Is that wrong?
    Mike Honcho
  4. #4
    Super Member
    Join Date
    Feb 2011
    Location
    Minot, ND
    Posts
    12,365
    Post Thanks / Like
    I too used to use the IPA mixture but have since switched over to a product (Eraser) designed for this purpose.
  5. #5
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,855
    Post Thanks / Like
    For me it depends on what LSP I'm going to apply.
    If I'm going to put down a wax or sealant, I don't do any post-polish wipe down. I'll simply buff off the polish and go straight to the LSP. For coatings I'll use a paint prep. The only one I've tried so far is Blackfire's Paint Prep.
    Drop by to see the latest at The Car Geek Blog
  6. #6
    Super Member AutoApollo's Avatar
    Join Date
    Aug 2015
    Posts
    209
    Post Thanks / Like
    Use a dry mf towel. If it doesn't come off with just a little-moderate pressure on the towel. Don't press any harder, use a spritz of 50/50 water and ipa mixed and it'll come right off
    Sent from my Nexus 5 using Autogeekonline mobile app
  7. #7
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    Gtehniq Panel wipe is BAR NONE the best inspection/wipe down product I've ever used. It has more lubricity than CarPro Eraser, Optimum Paint Prep, Gyeon Paint Prep and does not streak!! This is one product I will never change!
    IPA(even when diluted with water) is way too grabby and can micro-marr the finish.
    Quote Originally Posted by Desertnate View Post
    Not a good idea, as polishes will fill micro-marring and you're not getting the true finish. At least do a test spot and use a panel wipe to remove polishing oils and hope the rest of the car has the same paint system. I do one test spot with panel wipe on every panel to make sure I'm getting the finish desired.
    '03 Corvette Z06
  8. #8
    Join Date
    Dec 2006
    Posts
    607
    Post Thanks / Like
    That's an issue I see often that I can't get all the polish off so when I bring that portion of the car in the sun can't tell if holograms are real or just the polish. Will try IPA/water mixture this weekend and next time I place an order, will try Gtehniq. Think I have a bottle of Eraser in the basement, will try it too. Thanks all!
  9. #9
    Super Member Ancient1's Avatar
    Join Date
    Sep 2015
    Location
    Sun Prairie Wisconsin
    Posts
    292
    Post Thanks / Like
    Quote Originally Posted by WRAPT C5Z06 View Post
    I agree, I have used on glass to see how clean it wipes even. I liked it so much on the 1st order I made after my 1st use of it I got the 5l.
  10. #10
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    Quote Originally Posted by YankeeFan View Post
    Beyond that, even if you pull it out into the sun and you don't see residual polishing oils from wiping, most likely there's lubricating oils you can't see that are filling micro-marring. That will not be removed until you use a panel wipe, then you will have the true finish!!
    Quote Originally Posted by Ancient1 View Post
    NICE!!!!! I'm going to purchase a 5L of Gtechniq Panel Wipe once I finish the 500ml. Love this stuff!!
    '03 Corvette Z06
Similar Threads
  1. Replies: 5
    Last Post: 10-16-2018, 12:18 PM
  2. Quick, GO! New paint polish question
    By Rtrick87 in forum Auto Detailing 101
    Last Post: 08-22-2017, 01:31 AM
  3. Replies: 6
    Last Post: 10-29-2012, 07:01 AM
  4. optimum polish II quick question
    By op1001 in forum Auto Detailing 101
    Last Post: 08-31-2012, 08:46 AM
  5. Quick PoorBoys Polish Question.
    By swanicyouth in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 04-07-2012, 03:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
