Newbie polishing questions
I just have a few quick questions on polishing.
1. I have seen videos of the polishing process, they spray a bit of pad conditioner on before starting. Do you do this every time you put product on, or just with a new/clean pad?
2. Once you use a pad with a particular product, would you ever use it with another (ie less aggressive), even if it's clean?
3. Say you do a test spot and you are unsatisfied with the results. Do you start a new test spot or work the same spot?
Thanks for any help you can provide
Re: Newbie polishing questions
1. I always condition my pads prior to use with a quick spray of conditioner.
2. I use the same pads for all different types of products and applications. The key is to clean them as soon as possible after use.
3. Always same test spot.
1. I have seen videos of the polishing process, they spray a bit of pad conditioner on before starting. Do you do this every time you put product on, or just with a new/clean pad? I never use a conditioner.
2. Once you use a pad with a particular product, would you ever use it with another (ie less aggressive), even if it's clean? Sure, if it's clean.
3. Say you do a test spot and you are unsatisfied with the results. Do you start a new test spot or work the same spot? I would start another test spot to get the true result of that polish.
1. I do this when the pad is dry, so generally just on the first use. After I've cleaned it then it is usually damp enough that spraying it again doesn't do much.
2. Pads are part of the formula. You can sometimes get the same results using a light polish on an aggressive pad or an aggressive polish on a light pad. So I don't make the pads exclusive to any one product. Just clean them and use it again. You wouldn't designate bowls in the cupboard for only certain types of cereal, would you?
3. It depends on what you are testing. I did a car this week that had a repainted hood that had different issues than the factory painted fenders. So I tested a spot on the hood until I figured out the process and then did the same thing to the factory painted surface. If the whole car is painted with the same paint then generally you can just test a spot and figure out what product and pad and polishing technique are going to get the results you want and then repeat that process on the whole car. I always check my results fairly frequently around the car as I'm polishing just to make sure I'm not running into something that requires me to change up the tactic a bit, so I won't say that once you get your process figured out that you can then just do the rest of the car blindfolded all the time, but usually it doesn't change much from one panel to the other.
2019 Nissan Rogue SL
Originally Posted by Rsurfer
Yep, same here
By animescreen in forum Auto Detailing 101
Last Post: 07-18-2019, 07:33 AM
By nyjetfan in forum Ask your detailing questions!
Last Post: 04-08-2015, 02:37 PM
By kcochran0010 in forum Auto Detailing 101
Last Post: 02-12-2015, 10:24 PM
By Gordaskipper in forum Ask your detailing questions!
Last Post: 08-30-2012, 10:51 AM
By beercanbilly in forum Auto Detailing 101
Last Post: 06-29-2007, 03:27 PM
