Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Feb 2011
    Minot, ND
    12,365
    Re: Porter Cable/Trizact Sanding Stripes
    Quote Originally Posted by KenRobertson View Post
    Hi Everyone,
    I purchased the Lake Country 5 1/2 Inch Thin Foamed Wool Pads (LC-58-1255B) and tried them with the Perfect It #1 compound. I still can't seem to get a consistent shine even after following up with the Perfect It #2 compound and the thin Lake Country black foam pad.
    It just seems for my particular paint job the PC just can't generate enough heat to blend in my Trizact 1500/3000/5000 sanding marks that are left behind. There are no scratches left behind only the trail marks left from the PC and the Trizact pads.
    Below is a picture, it may be tough to see. To the left of the tape I have just compounded with (#1) and to the right I compounded and polished with (#2). The right has more shine definitely, but both sides still have area's that contain dull stripes.
    At this point I'm feeling my only option is to go and get a rotary polisher unless anyone can shed any light on my issues.
    Thanks for reading.
    --Ken
    Hey Ken,
    The 3M Perfect-it line of Compounds/Polishes are strictly for use on a rotary machine.
    Either run the 3M products all by rotary or pick up another line of Compounds/Polishes that are DA friendly to use with the PC.
  2. #22
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Quote Originally Posted by mylkman View Post
    Is the waiting 30 days for new paint to air or cure out? Factory paint wouldn't need this time right?
    Right and right.
  3. #23
    Aug 2016
    Howell, Mi
    118
    I have a slightly different twist. The Trizact Saning Discs are normally used with a sander and not a Rupes 21 buffer. With the 3' buffers your fine as these typically are abou 3/16 orbit. I would encourage a sander with 5" or 6" Trizact with a 3/16orbit. And use a surge protector.
  4. #24
    Quote Originally Posted by Dandy98 View Post
    Hi Dandy98,
    Where in this thread did someone state they were sanding with a RUPES BigFoot 21?
    Maybe I missed it?
  1. First time wet sanding kit - #3000 & #5000 Trizact Sanding Discs
    Last Post: 02-03-2017, 08:53 AM
  2. Sanding Wood with a Porter Cable DA Polisher
    Last Post: 12-14-2013, 09:10 AM
  3. Porter Cable and Color Sanding
    By hernandez.art13 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 05-01-2013, 11:19 AM
  4. Porter cable for wet sanding
    By kingweb50 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 11-17-2012, 12:58 PM
  5. Porter cable for wet sanding??
    By Jrgs-r in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-15-2011, 04:22 PM
