Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Jun 2016
    clear coat burn from scratchx use?
    Like the title states, I had a small scratch on my new 2016 Honda HRV. I decided to use Meguiars scratchx 2.0 to try and cover it up. I started softly at first and then I'll admit I used a pretty good amount of pressure and time to try and get rid of it more. now I have a patch of light/cloudy looking paint where I applied the scratchx (I posted links to pictures below). It still feels smooth as clear coat when I touch it and does not feel lower than the area around the patch. That's why I'm not completely sure I burned through clear coat (especially since the cars only 2 weeks old), or if maybe I didn't work the compound in correctly and so it hazed/clouded or micro marred the surface? Also not sure if I just somehow contaminated the surface and need to clean/polish it away. Looking to see if you wiser guys could tell me whether it is CC burn for sure or not, and where to go next? If it is burn through I'd rather not repaint right away, is there a way to at least cover it up for now? Or if it is NOT burn through, what is it and what can I do??? Links to before and after pics are below. Any and all help is appreciated. Please help!
    Imgur: The most awesome images on the Internet
    Super Member cleanmycorolla's Avatar
    Apr 2012
    Pasadena, CA
    3,805
    Re: clear coat burn from scratchx use?
    by hand?
    also where was the scratch? did you clay the area prior?
    Back to the full-time grind.
    Nov 2015
    Arizona
    1,419
    I'm having a hard time seeing the spot in question. What type of applicator did you use?
    Jun 2016
    Third link down shows the spot in question, right where my fingers are reflected. You'll notice the haze/discoloration. I used a microfiber applicator not terry cloth or foam, did it by hand. I did not clay prior, the car was recently washed and waxed professionally at a local place in town. Maybe I took off some wax or something?
    Super Member David Hayward's Avatar
    May 2014
    Mentor Ohio
    655
    Really hard to see from the pictures. If it did make it through or damage the clear coat did you notice blue on your towel or pad that you were working in the scratch x with?
    It's possible scratch x left behind some marring on the finish and it may be repairable using something like meguiars ultimate polish on a microfiber towel or foam applicator pad.
    Always keep in mind that polishing by hand allows you to apply some serious pressure with your finger tips, amounts much greater than we get with a foam pad on a da polisher. This can cause damage because you may not be aware of how much you are actually taking off of the surface.
    Jun 2016
    I did not see any paint transfer. I have ultimate compound and ultimate polish on hand. I tried using those with very light pressure (as I was afraid CC was already thin if not already broken through) not sure if I did not work them in enough to help though?
    May 2014
    Mentor Ohio
    655
    Quote Originally Posted by Dave59556 View Post
    Hard to say exactly. The first images make the scratch look pretty deep so it's very possible you are just wearing thin on the clear at this point. If you didn't see any blue on your towel or applicator while polishing it's probably not through the clear coat so that's a positive. Can you get in a little bit closer on the spot so we can get more detail.
    Does it just look dis colored or does it kind of look like fine scratches?
    Oct 2009
    493
    Try ult. polish on it
    Aug 2010
    New Jersey
    15,287
    Well, the good news is you got the scratch out! The bad news is it looked pretty deep and you could of, as you fear, have compromised the clear. I forget what Scratch-X is like now, they've changed it since it first came out. My recollection is the early version was very gritty, but later they went to a SMAT abrasive so it's more like M105.
    If you can live with it leave it alone. If you can't live with it you can try your Ultimate Polish again and if it gets better, great, if it gets worse, you know you've compromised the clear.
    Where are you located?
  10. #10
    Jun 2016
    Yeah no paint transfer. It looks more discolored/cloudy, but still has a Surface shine almost like the cloudiness is under the clear or something. It still feels just as smooth as the rest of the car. I had just had it washed and waxed professionally so did I maybe strip some wax or something in that area? I tried using ultimate polish, but barely rubbed it in at all for fear I had compromised the clear...would a glaze work to cover it up maybe? I'll try to get a closer picture. Im located in central Missouri so very hot and humid weather.
  1. Is this clear coat burn or not
    By estcstm3 in forum Auto Detailing 101
    Last Post: 04-13-2018, 09:12 PM
  2. Would clear coat burn be obvious?
    By jdgamble in forum Auto Detailing 101
    Last Post: 08-03-2017, 01:47 PM
  3. Possible clear coat burn
    By BennyHFP in forum Auto Detailing 101
    Last Post: 06-17-2014, 12:24 PM
  4. Did I burn through my clear coat?
    By Skimmer0220 in forum Off-Topic
    Last Post: 12-18-2013, 02:20 PM
  5. Can you burn through clear coat with a PCXP?
    By moparfan1986 in forum Auto Detailing 101
    Last Post: 12-15-2010, 12:55 PM
