Page 5 of 5 FirstFirst 12345
Results 41 to 43 of 43
  1. #41
    Re: Sign-up - Honda Extreme Makeover with Duragloss!
    Quote Originally Posted by rwright View Post
    Not bad considering the products used contain minimal abrasives. That is of course if only the products pictured were used.
    This car had an inexpensive paint job and the paint was single stage and soft which is the norm for most single stage paint, not all but most.
    Looks like it could use either a full wet sand session or at least some compounding.
    Not by this guy.... I was scared to use the 501 on it with a rotary buffer because with metallic single stage paint you're buffing right on the flake itself and if you buff just a little too much you completely change the appearance of the paint.
    Jeff and I did some buffing on the hood and trunk lid using the rotary buffer where most of the oxidation was but as soon as we felt we had the oxidation removed we turned the rotary buffers off and switched over to DA Polishers...
    The finish still has places that look "mottled" but experience has taught me when working on a paint job of questionable quality, don't press your luck.
    I took a few videos and the last one is a walk-around of the end results and if you look closely you can see the splotchy/mottled look to the metallic flake in the hood.
    Still, the car came in looking horrible and left with a smooth, hard shine.
    The car sits outside 24 hours a day, 7 days a week so I might have Coral bring it back, re-polish it lightly and then seal it with the GTechniq EXO and see how that works out since it's a single stage finish.
    Also here windshield has the normal wiper scratches from wind blown sand from the ocean so I'm also going to have her bring the car back to polish out the scratches on the glass.
    We used the Duragloss Nu-Glass to remove the water spots but to remove scratches "in" the glass we'll need a Cerium Oxide based glass polish.
  2. #42
    May 2009
    4,837
    Thanks for the clarification Mike! I remember reading about a low quality paint job but missed that it was single stage. I wasn't implying anything bad so please don't take it that way, I was just guessing based on the picture.
  3. #43
    No problems buddy...
    I was surprised to see that the car had a single stage paint but it made sense because of the extreme oxidation.
    Clear coats will oxidize but much more slowly than singles stage paints and gel-coats.
    The 501 is for removing oxidation on gel-coats and that's pretty much the same kind of chopping work we were doing to the single stage paint on this Honda.
    At least Coral won't have to deal with clearcoat failure and in this regard I kind of like single stage paint as you can fix oxidation, you cannot fix clearcoat failure.
  1. Pictures & Videos: 2003 Honda Civic Extreme Makeover - Duragloss
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 08-08-2017, 08:44 AM
  2. Sign-up: Tim's 1957 Chevy - Extreme Makeover
    By Mike Phillips in forum Wednesday Night Detailing Classes - Info & Dates
    Last Post: 11-12-2012, 09:49 AM
  3. Sign-up - 1999 Trans Am Extreme Makeover!
    Last Post: 11-08-2012, 02:54 PM
  4. Sign-up - Extreme Makeover - May 10th, 2012
    Last Post: 05-10-2012, 02:59 PM
