APC help.
I recently bought a Poorboy's APC. Primary its going to be used a De-greaser. Its an APC and have a lot of other uses. Since I don't have much experience with APC's can someone please share some pointers? Any dos and don'ts? Anything you people learn about APC's the hard way?
Re: APC help.
I use the Poorboys APC and like it.
What I've done is mix up several bottles of different concentrations. I have a heavy concentration to use under the hood and on exhaust. Another is mixed to the ratio listed on the bottle for general cleaning. Since I'm paranoid, I've got a third bottle mixed with a very mild ratio to use on leather seating.
I don't recall the ratio's off the top my head, so I won't try to guess.
Re: APC help.
Do a search man. You will find TONS of info.
4:1, and 10:1 are the most common dilutions
Re: APC help.
Bottle say 15: 1 for leather, vinyl, tires whitewalls, general cleaning. Also is it safe to make bottles according to dilution and keep them or its preferable to dilute when required to do a job?
Reason: Had to add another question.
Re: APC help.
If I had found any decent help, I wouldn't have come here. I'll appreciate if you have link/videos to post.
Re: APC help.
Thanks for the reminder. That sounds about right. I use 10:1 on interior stuff, and 4:1 for the strong version...I believe. I went off the ratios printed on the label.
I keep separate bottles and just mark them to ensure I can tell them apart. The stuff doesn't go bad, nor will it eat through the bottle, so mix up a big sprayer.
The only other tip I would have is don't spray the APC directly on to the cleaning surface unless you are cleaning under the hood. Anywhere else and I spray the rag and then wipe down the area.
Re: APC help.
Let me google that for you
fourth result is specific to poorboys APC
Re: APC help.
Thanks for inputs. Appreciate it. When I did little APC test, I didn't had sprayer around, so I just had to use towel and bottle (diluted). It works, only thing, I wasn't wearing gloves, it did sting a little on a finger for a day haha.
Originally Posted by Audios S6
Thanks for the input, I know the dilution part. Since I haven't worked with APC before I didn't know how to go about it. I googled up, how to use APC in tire cleaning, interior etc...and results started showing up.
